Question about Estate TEDS840JQ Electric Dryer
Dryer drum won't spin
I have taken my dryer apart because it wasn't spinning. The belt is nopt broken and I can hand turn the drum counterclockwise but not clockwise andy suggestions
    Genius:
  • 1,028 Answers
Remove rear panel remove screws in blower housing ck for objects in blower ..if you still have dryer apart remove belt from motor pulley and try turning by hand
Posted on Nov 15, 2008
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
Why dryer won't tumble?
The belt could be worn and stretched.
Jul 20, 2014 | Maytag MDG2706A Gas Dryer
Dryer won't spin
Was the belt shredded ( normal wear & tear ) or burnt through which could be a drum bearing or support problem .What does the drum feel like when you turn it by hand is it grinding & lump ? The fact that the motor runs with no load could by the start device faulty these are reasonably cheap to replace this is the small cylinder attached to the side of the motor with two wire connections . if your motor has not got one of these then its the start windings in the motor
Jan 11, 2013 | Maytag Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Drum won't spin on it's own but spins freely by hand.Was slow to start spinng before. Took front off but can not see belt at all, if it has one?
drive belt is normally accessed from the rear of the machine or if sealed rear from underneath(bottom) the belt is normally easier to get off the drive motor pulley first . Sounds like your belt is either already broken or has come away from drive unit or drum .
Jul 25, 2011 | Maytag MDE508DA Dryer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Dryer is heating but drum is not turning. What is the problem?
I would say belt is broken, if you turn the drum by hand and it spins freely then that is the problem, here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Dec 24, 2010 | Kenmore Dryers
Dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Estate TEDS840JQ Electric Dryer Logo
186 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
