Question about Microsoft Xbox 360 Console
Xbox360 wont read disk
I wanna know how i can fix it without send it out??????
  • Anonymous Feb 14, 2009
    When i insert a disk then it says ''reading'' but then the game doesn't start. Instead it says: ''open tray''.
What does it say when you put the disc in and trys to read? If it says unreadable disc then take a postcard or a little index card and put it in the tray while its closed with a disc inside and start from the left and swipe slowly to the right and it should start working
Posted on Nov 15, 2008
My xbox 360 wont read the disk but my friends xbox 360will read the disk . i wanna know what the problem is ?
Hi there abtorres97
What to do when your Xbox Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Microsoft if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Xbox to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $130 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a XBOX REPAIR GUIDE that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
xboxrestore
Feel Free to leave me a comment if you need further assistance.
Dec 24, 2010 | Microsoft Xbox 360 Console
My console keep saying open tray and won't read any disc
this is a very annoying problem when the disk drive is going bad (sometimes you can tap the top of console while its loading and it will read) you will need to send it off to get it fixed which is about the same cost as getting a refurbished console now or you can take console apart and change it yourself. takes about 30 min to do this. There are several different disk drive open them and you will see marking on disk tray Mitsubishi/samsung/benq are the ones I've fixed and repaired so far check out youtube under xbox360 disk drive replacement for visual guide if you don't know how and http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm to determine which drive you have and shop around for best price. good luck
Dec 22, 2010 | Microsoft Xbox 360 Console
I have a modded xbox360.. but after update the kinect dashboard now i couldn't able to play fable 3 , need for speed hot pursuit and assassin's creed brotherhood .... i already installed it to my xbox360...
there are series of problem in xbox360 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the xbox360 repair guide that will help you a lot Click Here
Dec 10, 2010 | Microsoft Xbox 360 Console
My xbox360 console wont read the disc. It keeps reading and then says open tray. How do i fix this?
well clean the disk. first of all second of all try another disk. if this works then it's a problem with this one disk and the souloutin to this is to play it from ur hardrive , hope i helped :d
Apr 06, 2010 | Microsoft Xbox 360 Console
My xbox360 thing that reads the games wont stay closed
all it is ur lens isnt in the correct starting position however its a little annoying when everytime u what a go of the xbox it takes about 20mins to get it to work but now iv fixed it properly well all i did is open the xbox comnpletly and get 2 dvd drive open it up i was shocked wen i opened up mine there was a dog on the lensand all over the whole grease on the bars were coverd in hairs i pulled the lens to the correct starting position and clean the dvd drive a best as i could amnd now it work perfect
this will fix it because over time this method will take longer and longer trust me 3rd xbox
Mar 19, 2010 | Microsoft Xbox 360 Console
Will not read discs when i put in a disc it says reading disc then it says op3n tray after about 5 or 10 seconds
Open tray error is common, even more so on Samsung drives.
To fix this you usually really need to open your xbox360 so you can get to the disk drive so you can open it for a self-service. BUT first try to fix it with a laser cleaning kit, they don't cost much to purchase and you can get them from most electronic shops and also eBay.
If a cleaning kit did not work, then the problem may be your tracks, the disk spin head or the belt that moves the tray (drive belt).
Once you have your xbox360 opened (lots of good video guides on YouTube on how to open the xbox360) you will have to open your disk drive.
When its open, clean the left and right tracks, they can get gummed up with dust, and even tar if the unit is from a smokers home, when the tracks are dirty, it can stop the tray going in all the way then games don't play. Also if the spin head is dirty (the plate the disk sits on to spin the disk) then it does not grip the disk fully and thus does not spin at full speed, giving you read error. Finally the belt inside the drive can be removed and can be boiled in water for a minute or to, this cleans it and brings it back to its original shape, this helps the belt regain lost grip and can also fix this error your having, but belt problems are more for Samsung drives.
You should use rubbing alcohol to clean the internal components of your drive without causing any damage, you could even clean the laser yourself using a high quality kitchen roll sheet or micro fiber cloth, with rubbing alcohol and gently pass it over the lens to clean it. Once you have done all this, close everything back up and see if the problem is gone.
If your still having problems then chances are you need a new laser for your drive.
The following YouTube video may help you http://www.youtube.com/watch?v=6GLS1dndQLU
Let me know if you need more help.
Jan 02, 2010 | Microsoft Xbox 360 Console
Xbox360 wont read discs
If you want to solve this problem soon then you should have to click on the link below, hope its helps...
Solve disc wont read problem
Mar 02, 2009 | Microsoft Xbox 360 Console
Big problem!!!!!
ok seems to me your xbox360 is buggered. Both of you.
How long have you had your xbox360?
Im guessing what a year or two? Beacause Ive got a uncle whos got a xbox whos xbox is broke because its standing up and when he puts a game in its ok, BUT when he takes it out.
It Comes out like ****. Its all scratched up etc. and its due to his HardDrive Failure problems. Basically the hard drive in his xbox360 is either Old , Nackerd Or just ****. SO Im suggesting go send your xbox360 to microsoft or something aka Warrenty. Or Go buy Xbox360 warrenty off GAME. www.game.co.uk <-- £50 - £60
Apr 01, 2008 | Microsoft Xbox 360 Console
My xbox360 doesent read anything it says unplayable disk
hi there, what you can do is maually clean the lens , free it frm dust and residue. be sure to clean it thoroughly so that it will not be damaged and wont read anymore cds.
hope this will hlp you.
Jan 28, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
