Question about Kenmore 44102 Front Load Washer
Object lodged in barrel
My washer is only 3 years old. I love it when it works. There's something in between the barrel and the housing that is stopping it from turning. We got it to turn and heard the object rattling inside but we don't know how to open the machine up to remove the object. The machine is a Kenmore Tumble Action Washer and the model number as printed on the inside of the washer is 417.43052200. Does anyone know where to find that kind of information? thanks Amy
Hi Amy, Check this link: http://www.repair-help.com/kb/index.php?article=177 Scroll down and under "ATTACHMENTS" it says: Console-Diagram.gif - Size: 36043 Control_Panel-Diagram.gif - Size: 61802 And you can click on either of those links and it's supposed to show you a picture of how to take your washing machine cabinet apart.
Posted on May 22, 2007
My Whirlpool WTW6400Sw3 is making the loud noise during the spin cycle. There is no water leaking anywhere. I can freely spin the inner basket without any grinding noise or any other noises. Do I need
stator ? maybe? did u check for a foreign object in between the drum and barrel? sometimes a pc of something can get lodged and cause loud noises
Feb 11, 2015 | Whirlpool Washing Machines
When it spins out it makes a really loud noise
It's more than likely the lower drum bearings. The sad news is they used to be covered by a ten year warranty that Sears took away because they were going broke changing the drum out. So if your washer is less than 10 years old the warranty will not save you and it will cost you between 2 and 3 hundred dollars. High efficiency washers, no matter the brand are pure junk. I've paid for mine twice in repairs. Grrrrrrrrrrrrr Good luck and maybe it's just something stuck under the disk at the bottom.
Feb 10, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Somethings stuck in my washer
nasty problem. At the door of the machine there is a very slight gap between the inner and outer drum. smalls can get caught here and work their way down. solutions: power off lay the machine on its soapbox side remove the outflow pipe and see if you can find the offending object. Trickier solution: power off remove the heater usually at the back look into the heater housing and see if its there. Removing a heater can be tricky.nut in the centre unscrew but not fully. Tap the screw shaft lightly with a hammer and the remove the heater. When replacing lightly grease the seal to ensure it goes back more easily. Always power off before working on a machine
May 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Noise in drum
see if you can locate the item stuck in the hole of basket an pull out with neednoise pliters
Mar 05, 2018 | Whirlpool AWM6100 Front Load Washer
I have a GE washer model wksr2100t8ww. It works fine but made a rattling nose during agitation. I opened the front to discover what looks like a piece of weed whacker string stuck and wrapped around the...
1) You r right it is NOT good! 2)Need Color and size to andswer that question 3)See if ur belts are missing a piece 4)Don't replace the belt unless you have done 1-2 and 3. Oil is normal. Like u tought oil in the bottom of the washer is cause of that object.
Oct 26, 2009 | Washing Machines
Clogged Hose
Hi, this sounds like you have something stuck quite firmly in the hose!! If you use a good sturdy stick then you should be able to move the object without any damage to the hose. Check along the outside of the hose first just incase something has pushed its way out of the hose wall.
Get back to me.........
Jan 02, 2009 | Electrolux Centralux Vacuum
Agitator noise in maytag performa machine
The noise in your washer tub could be caused by some object lodged under the agetator. Lift off agetator and check. Or somthing could have gotten into the sump tub. this could be a major job as you would have to remove the complete inner tub assy. One other problem I can think of it could be worn tub bearings. If the washer is 10 or 15 years old I would replace it,
ljtomega
Dec 03, 2008 | Maytag Performa PAV2200
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 44102 Front Load Washer Logo
435 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
