Question about HP Computers & Internet
My monitor looks like water spots or something on it ???
  • HP Master
  • 4,806 Answers
Please describe what it looks like in more detail
Posted on Nov 15, 2008
1993 f150 5.0 xlt. The first spot looks like it leaking something from behind the pullies. I'm not sure what it it but it might be the water pump. Second spot it's leaking something from behind the ov
that is your timing cover gasket. sending a picture of a 1996 ford 5.0 that need a bad leak see the yellow stain that was anti freezing at the timing cover
Dec 05, 2012 | Cars & Trucks
Unfortunatly while cleaning my LCD Monitor of my pc.. i dropped few drops of water and some how water just want inside,, now.. i have some black spots on my monitor though it works fine but still those...
Water and electronics do not mix.
Turn off your monitot and let it dry out for several days and then check to see if the monitor still works properly.
If not then you need a new monitor.
May 28, 2011 | Computers & Internet
White spot at the bottom of my samsung sync Master 153v monitor.it is quite disturbing please help in sorting out the issue
is it a large spot or just a pixel??
if it a large spot most likely the screen has been damage in someway, either something hit it and damged the lcd. if it just a pixel there nothing much you can do but replace the whole screen.
the same goes for the larger spot. you just have to replace the screen.
check on ebay for prices you can get a good deal.
Apr 14, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Screen has turned sideways
Right click on an empty spot on the desktop and scroll down to either the Nvidia or ATI control panel. Once you are in the control panel, look in the left hand pane and look for something that says, screen orientation or screen rotation. When you select that it may give you the orientation in degrees of a compass or rosary. Make sure you place the monitor orientation at "0" degrees. This will bring the screen back to normal.
May 16, 2010 | Tatung LD23HL Monitor
My hp laptop back ground rotated and i am not sure how to fix it
right click on the desktop in a clear spot and scroll down to the video control panel, it may be the nvidia or the ati control panel. If you have the nvidia control panel, look in theleft pane and you will see an entry for "Rotate" screen. Click on this until the screen looks right. If you have ati, it may say screen orientation or something similar.
Dec 26, 2009 | HP w2207 Monitor
I have what looks like water spots on inside of my lcd monitor how can i get the monitor open
You can't. Don't try. Are you sure the spots are not on the surface?
Clean your monitor screen with a soft rag and water only. If that doesn't work. you might try a solution of VERY MILD soap, like dish soap. And a very dilute solution. Wipe carefully. Never use glass-cleaning solutions like Windex or equivalent.
Mar 30, 2009 | Acer Aspire 5050-3242 Notebook
Dust on dishes after "clean" and spotted
The problem sounds like a hard water situation....Do you have hard water?...does your coffee pot take a long time to make coffee (an older coffee pot) if so you may consider a small water softener attached to the water inlet line or a water filtration device...as hard water will do just that..leave spots on the glasses and silverware as well as colored dishes, that look like little circles of whitish dried chemical or powder stains. Yes you can run a full bottle of vinegar in your dishwasher but monitor the cycle closely so it does not go into the drain cycle right away...and let it run through an extended wash cycle 2-3 times....before it drains so as to be able to maximize the effect...and as the aforementioned suggestion states you can also run some CLR through the system...BUT be CERTAIN to run it through several wash and rinse cycles after doing so as the chemicals in CLR are not healthy...and do not leave any dishes in as you do so (whereas vinegar is just Acetic acid and organically based). Also it is impossible for any concrete to have gotten into the dishwasher from anything poured down the kitchen sink drain since there is a valve in the drain pump called a "backflow preventer" that prohibits anything from entering the dishwasher. Also you may want to take out all the trays and remove the screem in the bottom of the dishwasher that covers the engine and pump assembly where the sprayer arm sits atop of. After doing so ( three -6 screws) clean anyfood or residue found ther out with a shop vac or something and reassemble.
I hope this helps....if so please let me know by rating me ...thank you....The Fang
Mar 24, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Samsung 710v test good
For anyone having this problem i suggest to get a manual from asnerejas. His notes helped me out totally.
Its not something you would spot looking at its inside...
Feb 19, 2009 | Samsung 710V 17" LCD Monitor
Having problem with buttons they are not working
The monitor thinks the "AUTO" button is depressed continuously. If water or something got into the button membrane and shorted it out it could cause this to happen. You would have to open up the screen to try and clean the buttons but that's not a guaranty.
Jan 11, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Spot/shadow on monitor and pictures
Does it appear on the photos if you look at them on a computer or print them out, and does the spot remain when you're using the menu?
If it's there all the time (on menus as well) it would suggest part of the display is starting to fail.
Also, have you done the shutter hold-up so you can check behind the mirror just in case it's something on the sensor (assuming it's not just the LCD that's failing)?
Jan 02, 2008 | Nikon D40x Digital Camera
Computers & Internet Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
