Question about Sanyo DS24424 24" TV
Jvc model digital ready
I have a 24" jvc flat tube my wife and I bought in 2002. The model number is AV-24F703. Is it digital ready or do I need the converter box as advertised.
  • Sanyo Master
  • 520 Answers
I'm sorry, but this model is not digital. You will need a converter box if you use an antenna.
Posted on Nov 15, 2008
Someone offered me a jvc hdtv av-56wp74,and one person said just the bulb in the lamp has to be replaced;then when called jvc they said i had to by colored tubes for 300.00 each,,,,who do i believe
The tubes rarely fail in this model so it may be a convergence issue instead. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
Here is an example video
Feb 14, 2012 | JVC AV-56WP74 56" Rear Projection...
I think the green is out. No matter how we play with the settings we cannot get any green to show in the pictures. What can we do to fix it? this is a JVC av 56p575
This is a CRT projection monitor - the image is generated by 3 separate tubes. If the green colour is missing then either the tube has failed or the video circuit to the green tube is faulty.
You must find out which by measuring the voltages on the green tube - if they are ok then you will need a new tube. You could find one here - not at this moment, only a blue one is available now
http://www.partstore.com/Model/Matsushita/JVC/AV56P575.aspx?p=1&z=50&c=256d4ef3182019bb69503a824cf22601&bs=Category&bd=Asc&ms=Price&md=Desc&k=&on=&cfilt=#1
Apr 06, 2011 | JVC AV-56P575 56" Rear Projection...
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Mar 06, 2011 | JVC AV-27730 27" TV
JVC 65 inch AV-65WP55 tv, the color red is failing
The tube is old. You need to contact a service center. He may try to boost it from inside. If it doesn't work, then need a new tube.
Jan 09, 2010 | JVC AV-65WP55 65" Rear Projection...
JVC av-35750 digital or analog???
Unfortunately this TV does not have a digital tuner built in.
Is not digital ready.
Jun 28, 2009 | JVC AV-35750 35" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
JVC AV-56WP74
You would need the service manual in order to change the picture tube properly as there are dangerous voltages stored inside the tube also the tube would have to be set up properly as well. You can get the service manual for your model at the following link. They will email it too you right after purchase. Heres the link.
http://servicemanuals.vstore.ca/
May 28, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC MODEL NUMBER AV-20N31
http://www.bruzziforum.com/vbf/showthread.php?s=7acab0606b230f96d8ded2112db03bf4&t=34
Nov 15, 2007 | JVC AV-56WP74 56" Rear Projection...
The picture is only producing the basic colours red green and blue
Can you post a picture of the Tv with the issue stated?
Feb 28, 2007 | JVC AV-24F703 24" TV
Sanyo DS24424 24" TV Logo
109 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
