Question about Apple iPhone Smartphone
Trying to set up my email to come to my phone
I have an email account at excite.com, and am unable to get it set up to go to my phone. I have tried several things but have not gotten it to work.
    Problem Solver:
  • 13 Answers
If you know what type of service you have from excite it should be pretty simple, however I know nothing about excite. Usually when email doesn't work from the perspective of the phone it is incorrect info in the setup on the phone itself. Key things to check are "incoming server info...you may have to try a few but i expect that it will be either a simple pop3 or an imap.excite.com typr; same for outgoing mail server prob smtp.excite.com or some variety; I believe it that f you leave the port number as it comes up that it defauls to the correct setting and that the defaults are based on the security setting. From there you have to specify how and how often your phone checks for/ receives mail.
The apple website has excellent info about most problems. Just go to the iphone FAQ first and if no luck there just scan thru theiphone support menus on the apple site.
Sam Bass
Posted on Nov 17, 2008
Unable to verify account
Call Apple they are great and know the phone better then anyone.
Dec 13, 2014 | Apple iPhone 5S
Help yahoo com
Symptoms You can try these basic steps to troubleshoot Mail on your iPhone, iPad, or iPod touch. If you see a specific error message, follow the basic steps, then the steps for that error message. For example, you might see one of these messages:
  • Cannot get mail
  • Unable to move message
  • Username or password is incorrect
  • Relaying denied
  • Email address rejected by the server
Resolution First, try these basic troubleshooting steps:
  1. Tap Safari and load a webpage. If you can load a webpage, then your device has Internet access. If you can't load a webpage, check your Wi-Fi connection or try a different Internet connection:
    • Try a different Wi-Fi connection.
    • If your iOS device has an active cellular data plan, tap Settings > Wi-Fi and turn off Wi-Fi.
    • If the affected email account is provided by your Internet provider, see if your issue is resolved while connected to your home Wi-Fi network.*
  2. Log in to your email provider's website to make sure that the account is active and the password is correct.
  3. Make sure your settings are correct using Mail Settings Lookup.
  4. Restart your iOS device.
  5. Delete the affected email account from your device.
    1. Tap Settings > Mail, Contacts, Calendars.
    2. Tap the affected email account.
    3. Tap Delete Account.
    4. Add your account again.
* If you can only use your email account while connected to your home network, this might be a limitation put in place by your email service provider. For help, please contact your email service provider.
Follow the steps below for specific alerts.
"Cannot get mail" Make sure you entered the correct password. If you enabled two-step verification through your email service provider, contact them to see if you need a special password for your iOS device.
"Unable to move message"
  1. Tap Settings > Mail, Contacts, Calendar, then tap your email.
  2. Tap Account.
  3. Tap Advanced.
  4. Tap Deleted Mailbox and make sure it's set to Trash.
  5. Tap Advanced > Account, then tap Done.
    Note: If you see the issue again, repeat steps 1 through 3, tap IMAP Path Prefix, then Inbox. After you make your changes, tap Account, then Done.
"Username or password is incorrect" with POP3 account Before you check your email on your iOS device, close it on your computer and other devices.
To see if your account is a POP3 account use the Mail Settings Lookup tool or:
  1. Go to Settings > Mail, Contacts, Calendars and tap the account.
  2. Look for the label POP ACCOUNT INFORMATION.
If your email provider offers IMAP, remove the POP3 account, then add the account with your provider's IMAP settings. POP3 communicates with one mail client at a time. If more than one mail client tries to connect, you might see a username or password error.
"Relaying denied" or "Email address rejected by the server" when you try to send email This error indicates that either an email address is incorrect or your settings aren't correct for your current connection. Make sure the email address is correct for messages in the Outbox or try a different port:
  • If you're on a Wi-Fi network connected to the same network as your email domain, such as your Cable or DSL provider, try port 25:
    2. Tap your email account, then tap Account.
    3. Scroll down and tap Outgoing Mail Server.
    4. Tap Primary Server, then tap Server Port.
    5. Delete the current port and enter 25.
    6. Tap Done.
  • When you connect to a cellular data or a different Wi-Fi network, you need to use an alternate port and authentication, if your email provider supports it. The most common alternate ports are 465 and 587. Check with your email provider for specific settings.
If you still can't send email, you can set up an alternate SMTP server.
Get help troubleshooting iCloud Mail.
Aug 29, 2014 | Yahoo Mail
How do I change my default email password on the xperia u _ android. Had to change my password on my laptop for hoty and my email was on automatic sign in so it won't let me access my hotmail on the...
I had this problem, I am not 100% on what fixed it but try this:
In email:
* menu -> accounts
* menu -> account settings
* Its my gmail, so I selected google.
* next
* Sign in
* Enter the username and password for your existing account
* It will say "Account already exists; There is already a whatever@gmail.com account on this phone". But as soon as it said that I started getting emails again. So I am assuming that it updated the password.
Aug 04, 2012 | Cell Phones
Unable to find my gmail email "anna4jewewls69@gmail.com" or my gmail account.
contact gmail technical support & ask them what to do
Mar 15, 2012 | Google Gmail
I'm unable to create email accounts in samsung chat c3222 model. I'm using vodafone live as my internet connection. At the same time i was able to connect to internet through browser. the settings for both...
maybe your network doesn't support that program or there's unfamiliarity in the server,
keep trying, if it doesn't work,
you can create an email account from your P.C and access it from your phone
I HOPE THIS SOLVES YOUR PROBLEM
Jan 19, 2011 | Samsung Cell Phones
I am trying to set up an email on my phone but it keep on saying dns error/failed how do i set up an email from my phone?
just giving you an idea,
on your computer, login to your email account then go to your account settings.. just copy your email configuration to your mobile..
on menu > messages > settings > email > email accounts
> Your email account.. input your configuration from your email..
(e.g. smtp.mail.yahoo.com & pop.mail.yahoo.com) for yahoo accounts
on menu > messages > settings > email > email profiles> choose your connection (e.g. wifi connection, gprs/edge connection)
May 28, 2010 | Samsung Star GT-S5233 Cell Phone
Can't validate Comcast email account on new cell phone
http://blog.macroaxis.com/2009/08/29/signing-up-for-your-new-internet-and-phone-service-with-att-or-comcast/
See numbered paragraphs 1 & 2 -- don't know if they contain any info to help you
http://www.crn.com/security/208401271;jsessionid=EITK0E1LBNUDBQE1GHPCKH4ATMY32JVN
This is my bet for what's happening. Service is STILL DOWN for members in different areas.
Hope this helps
Sep 08, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Unauthorized access into my account
you can't only yahoo admin knows.
try this security tips from their website
Nov 03, 2008 | Yahoo Mail
Excite.com e-mail
I cannot download excite.com Email folders (incoming, sent etc.).all I get is the icon indicating downloading and on lower task bar over word "done" a caution icon or at times error on page. Please help at wits end!
Jan 03, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
1,503 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
