Symphonic TV model WF2702: wireless sensor for remote controling on/off, sound, channel not working. What is the approximate repair cost by a qualified TV tech?
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: had a power surge on
Double post
Posted on Jan 31, 2008
MikeMaierTV
  • 206 Answers
SOURCE: TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Posted on Mar 06, 2008
SOURCE: The TV does not pick up the sensor from the remote control.
FYI All, I finally got around to actually fixing the remote sensor on the TV. The sensor is located behind the O in the Sony logo on the front of the TV on the HC board. It is easily removed by removing the back panel of the TV and unscrewing the lower front-screen brace (there's an S sensor attached w/ one screw which needs to be removed first). Once the brace is removed, you can pull out the board which has a 3 pin connector w/ 2 grey wires and one white wire. simply disconnect this connection to remove. On my board, I found the 2 zener diodes were bad, I simply replaced w/ Radio Shack 12V zener diodes and all was good-to-go. I happened to run across Radio Shack part 270-640, which is a compatible IR sensor, didn't need it, but it will work if your sensor has gone.
Posted on Jun 27, 2009
atelier mj
  • 70 Answers
SOURCE: tv stopped working and red light started to blink
this problem can be solve by changing the 2 IC of convergence. part # STK 392-110. It would take 30 to 60 minutes to open change and reclose.
Posted on Apr 23, 2010
I have a 27 inch black Symphonic t.v model wf2702. with this t.v I having been able get a picture with my Apex dvd connected to the t.v.could you please hlep me withthis
www.symphonic.us/pdf/spec/2004/ST419E.pdf
Please find a user manual above, and a service and repair manual below.
http://elektrotanya.com/symphonic_st413e_st419e.pdf/download.html
You need to check, that BOTH units are set to correct video format, IE: NTSC of PAL. The Connections are wired up correctly, the Correct External INPUT has been selected on the TV. Remember you do NOT use "Channels" to view Externally connected devices. You always wire color to color on both ends of the equipment. Please follow the manual.
Jun 06, 2010 | Symphonic ST419E TV
I do not have a remote control for my Symphonic tv and I am trying to put the tv on channel 3 or 4 but I can't. It goes from channel 2 to 8. Please help.
Below are some places where you can purchase a symphonic remote control. But if you don't fancy buying one why not tune channel 8 and upwards to the station's that your are after and just forget about the 3,4,5,6,7. My quess is that the tv system is set to skip these channels. If you go to Menu > tv settings, check out the channels that you are skipping, it should be in the installation part of the tv setting's menu. Make sure that where it say's SKIP > OFF on all of the missing channel's.
Hope this is of some help. Bit long winded but hey! :-)
Hughie.
www.remotecontrolscenter.com/symphonic/ -
www.tootoomart.com/buy-symphonic+remote+control/ -
Jun 17, 2009 | Televison & Video
No remote, need code for universal remote
Try this method:
Turn on the device you want to program.
Press and hold CODE SEARCH until the indicator light lights then release code search.
Press and release the device button you are programing TV, the indicator light will blink once then remain lit.
Press and release OFF/ON until your device turn off.
you may have to press upto 200 times
When your device turn off press enter button the indicator light will go off,good luck.
Jun 02, 2009 | Symphonic WF20D4 TV
No tv remote
Go to Radio Shack and get an universal remote control, mine is a Phillips Universal and just program it to your tv. It has a tv/vcr input to let you switch to the right "input"/channel.
Sep 11, 2008 | Symphonic ST420FF 20" TV
Codes for tv
usually the universal remote comes with a code book. if you're TV is not on it the remote won't work. But most TV's are on there. If you can't find the TV, go to the ORIGINAL COMPANY of the TV. (RCA, Samsung, etc.)
Jul 03, 2008 | Symphonic ST419E TV
Remotes quit working
Take your Tv to the Technician to check for you if the sensor is working properly.
Mar 24, 2008 | Symphonic ST419E TV
Television question
****. Same problem. No luck on the down from channel 2 thing. Fuckin old crappy tvs.
Jun 21, 2007 | Symphonic ST413C 13" TV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
