After a rain storm the inside of the unit is filled with water. Is this a problem with the integrety of the grill
SOURCE: I have a ducane grill and it will not get hot. I
The most common cause of reduced flames is a pressure problem. Could be the gas regulator for the grill. When the burners are on try giving the gas regulator a tap with something hard and see if they change size. If they do then the rqulator could be sticking. And there is a very small hole on the regulator called a vent. If this hole gets plugged with dirt or grease you can get a low pressure problem. Look very carefully on the regulator housing for this small hole and verify that it is clear. Try using a small metal wire(like a tie strap for sandwich bags) to make sure it is clear. Also verify that the tank(if propane) is not overfilled. An overfilled propane tank will cause a pressure problem. You can turn the relief screw on the propane tank until no more liquid comes out to see if this fixes your problem.
Testimonial: "I will try these suggestions, thank you for the information"
SOURCE: Ducane Firelight Campstove/Grill Regulator/Hose Assembly
I have a a never-used Ducane Firelight Campstove I will sell for $50 . I believe I paid $189 or more for it. However, I do not know in which area you are located
