Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Double words and blurred picture,
My RCA TV is showing double words and blurred picture please advise me on what I can do ?
  • mrw1973 Nov 16, 2008
    Ihave the same problem with my unit.. Do you think this is a cronic problem with this particular model. Already had to have the high voltage transformer changed. $245.00 to fix it.
    Genius:
  • 1,030 Answers
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Posted on Nov 17, 2008
Blurred picture, double picture on the tv screen
MB, your set has one or more defective LCD panel tabs. The only true fix is to replace the screen which will be big $$$. There are youtube videos that will show you how to patch the problem. Just search LCD panel tabs and several videos should come up.
Mar 31, 2013 | Samsung Televison & Video
Fuzzy with double picture
TV is blurry as if expanded, do not know how this happened. Words are blurred, picture is not crisp anymore. Help please.
Aug 12, 2010 | Philips Magnavox 27MS343S 27" TV
Bottom lft of tv looks like turning page, picture blurred and word double-vision
TV needs convergence output ICs replacement as existing got defective and causing above said symptoms.
Let me know if you have additional question.
Thanks.
Jun 21, 2010 | Sony KP-51HW40 51" Rear Projection...
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
RCA P56812BL, Flickering Static like lines
Check all inputs and tuner, that you can, and report back.
Apr 19, 2010 | RCA P56812BL 56" Rear Projection...
My RCA 54 in projection tv shows a blurred picture
On the RCA - Color Wheel Encompass Parts Distr look up online or call them 1-800-638-3328 Other TV could have Bad capacitors pull back off if any of the caps are puffed up on top then they are Bad 1000uf 16v , usally find 2 or 3 bad
Oct 08, 2009 | RCA HD50LPW175 50" HDTV
My RCA TV guide words is blurred but the
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Sep 06, 2009 | RCA F25654BC 25" TV
Blurred words
I have a hard time to vision that it is just the words, is the picture blurred also? If you are inclined, you have to take the back cover off. With a medium to small INSULATED screw driver you will see a big transformer that has a HIGH VOLTAGE lead going to the picture tube. There should be one or two black plastic screws on it (hence the insulated screw driver use) adjust one or the other to see if picture improves. Will not take much adjustment, but must take CAUTION as not touch the metal part of the screw driver, we are talking 15 to 32K volts. Naturally the tv has to be on to do this.
Jan 18, 2009 | RCA F25654BC 25" TV
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 11, 2008 | Samsung HC-P4752W 47" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
181 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
