To put music on my sandisk e270 i have just been dragging and dropping the files on to the player. This seems to work the majority of the time however sometimes i will end up with the player listing tracks multiple times (using windows shows only one copy of the track) and i also have a track listed on the player that isnt there/wont play and is unable to be seen in windows. I certain it isnt a problem with compatibility all the tracks are wma so should all be fine.
I have a question: how do you change the summary of an mp3 file. The message box doesn't allow me to just change it right on the spot.
All files need to have filenames and titles ("title" field in the summary under file properties on your PC). Otherwise the player will list it as "unknown" and it will NOT play. You have to drag it out of the player, rename, and then drag it back, if you're in MTP mode (which you SHOULD be!). Multiple copies of the same track sounds like you have some tracks listed under different artist names--you gotta keep a clean library!! Go back and check all the summary attributes for your mp3 files... Of course, you're using WMA files so who the heck knows. I would be sticking with mp3 format, if you want my opinion.......
havin troble adding music to my sandisk sansa shakerand how do u drag n drop
