Emerson Television I hooked up my Emerson Television and it says "No Signals" I have DTV hooked up to it. The box is on and running and all over televisions in the house are working fine. I have even done the channel search but I am still getting "No Signals." The television has worked fine and I have not had any problems with it at all until now. I have made sure all the connections are there and everything, I even double checked the other DTVs in the house to make sure I have hooked everything up correctly and everything is fine.
    President:
  • 2,992 Answers
With a cable or DTV converter box hooked up, the only channel the TV will find is channel 3 or 4 (depending on how the box is set). Make sure the set is on the right channel and you should be OK. Also make sure the cable is good. If you have several TV's connected to the same source you might have a bad cable or splitter somewhere in the chain. Hope this helps!
Posted on Nov 18, 2008
What is a converter box for tv
A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set. It may refer to over-the-air broadcast television signals received by an television antenna, or to cable TV systems which switched to digital cable. It normally does not refer to satellite TV, which has always required a set-top box either to operate the big satellite dish, or to be the integrated receiver/decoder (IRD) in the case of direct-broadcast satellites (DBS).
In North America, these ATSC tuner boxes convert from ATSC to NTSC, while in most of Europe and other places such as Australia, they convert from Digital Video Broadcasting (DVB) to PAL. Because the DTV transition did nothing to reduce the number of broadcast television system standards (and in fact further balkanized it), and due to varying frequency allocations and bandplans, there are many other combinations specific to other countries.
Feb 21, 2013 | Polaroid FLM-3232 Television
Since this Curtis RT700 TV is analog, is there an adapter available to make it digital usable?
Yes,the analoge tv must hook through a box that called a Digital Converter box to get a Free AIR DTV broadcasting tvs channels signals.These Digital Converter boxes are no longer on sale by those regular big boxes stores like Walmart or Target.Tries webites like Amazon.com,Ebay.com to a Digital Converter box for any analoge tvs to uses.
Sep 15, 2011 | Curtis RT700 7 in. Portable Television
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Don't know how to activate HD reception on M and S HD ready tv
Not an HDTV this is an standard thin flat tv,not possible to get HDTV,only get DTV with a converter box for free air,or cable,satalite or telicom signals than not require converter box.
Oct 22, 2009 | Emerson EWF2004 20" TV
Dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Jun 21, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Digital tv not picking up digital signal??
According to the manufacturer, the EWL20D6 Television is not digital ready. If that is the case then you will have to use a converter box in order to receive the digital channels.
Dec 20, 2008 | Emerson EWL20D6 Television
No signal on dtv do I need a DTV antenna
You have an awesome antenna - every one should have one like it!
An antenna that used to work with the older analog signals will work with the digital ones. What you have to remember is that analog systems though subject to ghosting, were brutes signal wise ala the metal on older cars. Digital signals are frail and even tree leaves in between the antenna and transmitter can have adverse effect on signal received.
If the sound is weak on your set that is a function of your sets audio section. Somewhere you are losing gain and/or amplification. If you have an audio output you might consider hooking that up to one of the audio inputs on audio receiver. It will work fine and that is what I did with my unit.
Sep 05, 2017 | RCA HD52W59 HDTV Projection Television
Is this a digital television? will i need a digital box with my television in 2009 ?
The "DTV ANSWERS" website says that any TV made since 2004, has a built-in digital tuner and will not require a digital converter box. If you currently receive your TV signals from your cable, satellite, or phone company, you won't need a converter box, even if you have an older non-digital TV. Only people with TVs made before 2004, will need to purchase a converter box, if they don't use TV signals from cable, satellite, or phone companies.
You might want to visit the RCA website, to see if they have a phone number to call, for any additional questions.
Jul 06, 2008 | RCA F27665 27" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
