Question about Bosch Dishwashers
Bosch - quick wash time is now 88min! why??
We have Bosch dishwasher SHY66C. Something happened, and now when i chose quick wash, it takes 88 min instead of 38. We tried rebooting it by holding two buttons at the ''cancel drain'' line, but after that it's still 88. Is there another way to reset it back to original time?
3 Suggested Answers
  • 54 Answers
SOURCE: I actually don't know what
On a Bosch dw, it has a light sensor to sense soil in the water.. if the control feels that the water going through the sensor is not clean/ or clean it will add or minus time..one thing you can do is make sure that your drain line from dw to sink drain is cleared of debris.. also, make sure you clean the filter at bottom of dw and make sure its reinstall correctly if you haven't already do so.. if your dw finish the cycle and come out clean, then the time on your dw is fine,, but if it don't finish and come out dirty.. then, it could be something other, but don't know til I get the full details on problem.. help this will do it for ya.. good luck.. mike
Posted on Jan 23, 2009
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher SHU43C02UC/38 runs the quick
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is the purpose of the "1" indicated in the display, a heating problem.
I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony.
Good luck.
macmarkus :)
Posted on Mar 12, 2010
Testimonial: "Thanks so much for the help - it was right on. "
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The timer on my dishwasher is really off. No
the best thing to do is replace it ... but make sure all the connectors are in place
Nov 14, 2009 | Bosch Dishwashers
Bosch exxcel multi programme ....programme gets to 1 min and then stays there. on the quick cycle on the auto cycle it gets to 60 min then returnsto 140min on the timer... thankyou
this is caused by incorrect water levels the appliance takes in too little water at final rinse and generates erro code 1 this is what you are getting it isnt 1 minute to go it will need the dishwasher equivalent of colonic irrigation several tubes will be full of fatty deposits,using the quick wash a lot will make this happen more often you will need an engineer to sort but shouldnt need any parts.
Aug 06, 2009 | Bosch Dishwashers
Bosch Exxcel Type S9N61B
IF YOUR DISHWASHER IS OVER 3 YEARS OLD IT HAS PROBABLY BLOWN THE HEATER IF THEY ARE USED ON REPEATEDLY LOW TEMP WASHES FAT CAN BUILD UP AND DESTROY THE ELEMENT ON A 35 QUICK WASH IT SHOULD HEAT UP WITHIN 12 MINS OF STARTING IF NOT HEATING APPLIANCE WILL WASH FOR UP TO 3 HOURS IN COLD WATER IF CYCLE TIMES ARE NORMAL BUT NO HEAT IS EITHER A THERMOSTAT OR PCB FAULT THE FORMER IS LESS LIKELY,YOU SHOULD GET AREADING OF AROUND 25 TO 30 OHMS ACROSS LIVE AND NEUTRAL AND INFINITY ACROSS LIVE TO EARTH AND NEUTRAL TO EARTH.
HOPE THIS HELPS
Jul 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I actually don't know what type of Bosch I have. I know that is a problem, but maybe you can still help. It has a simple panel that says: Pot Scrubber, regular wash, quick wash, rinse and hold. When I turn...
Jan 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch aquasensor
no it should be plumbed into the hot side... it will not wash untill the water is hot enough ...
Aug 20, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
that model only have white panel
May 09, 2008 | Dishwashers
Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
287 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
