Question about KitchenAid KBMC140HSS Convection/Microwave Oven
Keypad going out
The keypad keeps going out on my kbmc140hss. It has happened now three times in 1.5 years. Kitchenaid keeps replacing the keypad,under warranty, but the problem keeps re-occuring and I keep having to pay a service charge. The last itme it happened, the repair company they suggested had replaced 3 door switches thaey claimed were also bed, to the tune of $150.00. Any other reasons anyone knows of that could be causing this to happen?
  • KitchenAid Master
  • 9,156 Answers
The main reason door switches go out is by opening the door while it's cooking, instead of hitting the STOP button first. Otherwise, like anything man made, they can fail. And for safety's sake, they should all be replaced when one is bad. If a keypad is failing repeatedly, I would suspect outside contamination or an inherently bad design. But I've not before heard of repeated keypad replacement. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Hope this helps.
Posted on Nov 22, 2006
SOURCE:
Some buttons on microwave keypad won't work
Keypad/keypads once faulty cant be fix . Buy a nex keypad
Sep 01, 2014 | KitchenAid KCMS1555RSS Stainless Steel...
Litchenaid KEMC377KSS05 says DOOR and microwave wont start
follow the next step and use the common sense: God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 03, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I am looking for a replacement for the Kitchenaid KBMC140HSS microwave. I need the same size or one that will fit into the opening after replacing this one.
You should be able to contact Kitchenaid customer service here to see which model may be a "drop-in" replacement.
If you might want help with repairing it, please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit (KBMC140HSS#), and your symptoms.
Feb 09, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchenaid microwave model KBMC140HSS03 will not start, sounds 3 tones when any key is pressed. If circuit breaker is turned off and back on it works for awhile, but goes back to 3 tones, sometimes whil...
Your membrane keypad is shorting.
It comes as an assembly, so it's pretty easy to replace yourself. It is part number 4453420 and you can get it here for $235.33 plus shipping.
You can also find helpful exploded views at that link.
The picture below shows you how to unlock a typical membrane keypad connector.
Jan 09, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
Sep 08, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid microwave hood combo KHMS155LSS
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME; while you are on vacation or at work or at night while you are sleeping etc. Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&E (Sears) out to fix it. Although they will fix the problem, if the keypad fails again, the underlying logic self start defect is still present. You should be under warranty if it is above model. Please be polite, insistent, but polite. With KitchenAid's pathetic quality in recent years, their customer service reps get more then an earful. Also, please go to the Consumer Product Safety Commision website at www.cpsc.gov and post a Report Unsafe Products report. This will help get this model recalled before someone loses their home or life. I almost had a fire this past Monday, Labor Day, 9/7/09 when my machine self started at 3 AM with a package of bacon left in it to thaw at room temp for the morning. What a smokey mess. Chinese made garbage. Shame on Whirlpool. Long live Hobart!, please buy back KitchenAid and bring back the lost quality.
Jan 02, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KEYPAD STICKING AND STOPS WORKING
Obtain a replacment keypad and replace it. The non serviceable contacts inside of the key pad or going bad.
Dec 31, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid KBMC140HSS Convection/Microwave Oven Logo
117 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
