Question about GE 32GT660 32" TV
SPECIFIC FIX FOR GE 32GT660
I WAS WATCHING A GAME ONE DAY ABOUT 2 WEEKS AGO WHEN ALL OF A SUDDEN THE TV STARTING CHANGING CHANNELS. THE SET HAD BEEN SET ON CHANNEL 3 BECAUSE I WAS WATCHING CABLE. WHEN I TURNED THE CHANNEL BACK TO 3 IT STAYED FOR A FEW MINUTES AND STARTED CHANGING ON ITS OWN AGAIN. THIS PROBLEM GOT PROGRESSIVELY WORST. IT GOT TO THE POINT WHERE IT WOULDN'T STAY ON CHANNEL 3 OR ANY OTHER CHANNEL AT ALL. IT CONTINUED TO WORSEN TO THE POINT WHERE THE UP / DOWN BUTTON CEASED TO WORK PROPERLY. THE CHANNELS ONLY CYCLE DOWN. AT ONE POINT YOU COULD CHANGE THE CHANNEL BACK BY PRESSING THE UP BOTTON. NOW WHEN YOU TRY THAT THE CHANEL DISPLAY ONLY FLICKERS BETWEEN NUMBERS AND ONCE THE BUTTON IS LET GO, IT CONTINUES TO CYCLE DOWNWARD. IF THE CHANNEL UP BOTTOM IS PRESSED FIRMLY AND HELD, THE CHANNELS WILL GO UP, BUT AS SOON AS THE BUTTON IS LET LOOSE, THE CHANNELS START CYCLING DOWN AGAIN. NOW THE VOLUME BUTTON SEEMS TO BE GOING AS WELL AS THE MENU BUTTOM. WHAT DO YOU THINK THIS IS ANS HOW MUCH ON AVG. SHOULD IT COST TO REPAIR?
  • Angelo Greene Nov 21, 2006
    NEED HELP FAST - THE SUPERBOWL IS COMING UP! HOW LONG SHUOLE A REPAIR TAKE AND HOW MUCH SHOULD IT COST?
I have the same problem, except that it would turn on by itself and then start changing channels. I had a can of compressed air and sprayed the button areas to see if there were sticking. It worked for a coupe of days, then started happening again. So I searched the web and found a response to a question someone else posted and the ensuing reply "most likely you have one of 2 things going on one is the foam between the buttons and the switches or you may have a switch getting leaky and would need replaced" Looks like I may have to taking the cover off and find some type of electronic cleaner, or replace the buttons. I find it odd that I got hits for the same issue with the same model. hhhhmmmmm?
Posted on Apr 05, 2007
My lc320slx is about a yr old and two days ago we were sitting watching tv and all of a sudden the channels started rsndomly changing, I thought something was on the remote control but there was nothing....
The control on the television itself is probably dirty or malfunctioning. Unplug the television and remove the back. Find the board underneath the buttons on the TV and gently clean off any dirt using rubbing alneeded and cotton swabs if needed.
Apr 24, 2011 | Sylvania LC320SLX 32 in. LCD TV
I got a new Sanyo Vizion 46" LCD tv as a present about 2 weeks ago. I noticed since the first day when I change channels I can still see some images of the previous channel I was watching. Should I...
Return the tv for another one for the replacement.This tv have a problems,call a delay prograssive scan.That why u see the jet trails of the previous pictures.This problems,will not go away,but will getting worse and even might have a permanent pictures screen burn of the previous pictures in LCD screen panel too.
Nov 29, 2010 | Sanyo DP46849 46 in. HDTV
I bought a 19" element
Is a tv power glitch,shutdown,start again,tv have no problems,wright?Not a problems,if only happen one?If it happen many times,tv have power supply board problems,take ur tv warrenty repair or return ur tv,where u bought it,get a new tv replacment.
Nov 23, 2010 | Element ELC-HS321 32 in. LCD TV
GE #32GT660 won't turn on.
Your set is possessed! Just kidding. The answer to your question is in your last statement. If you smell something burning your set has experienced a voltage overload which caused a component to overheat and burn and that failed component has rendered your set non-operational.
Unfortunately, this is not an easy fix and will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the set.
Aug 28, 2009 | GE 32GT660 32" TV
Can't access Video Channels.
Try hitting the input button on your remote.
Jan 10, 2009 | GE 32GT660 32" TV
GE TV Model 32GT660
You should be able to access by pushing the menu button. If not I would look for a universal remote that will work for that TV.
Jan 02, 2009 | GE 32GT660 32" TV
RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
Ge 32gt660 problem
it could be just the fuse which is located near the power inlet in the back.
Jan 13, 2008 | GE 32GT660 32" TV
Sony trinitron tv KV-32LS36U changing channels
You may have a control button sticking either on your remote or on the front panel of your set. I have run in to this on several sets. When this happens, some really strange things will happen including problems like you're having. Stargazer
Jun 13, 2007 | GE 32GT660 32" TV
Blurry Screen
ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Nov 13, 2006 | Jensen TS2750J TV
Televison & Video Logo
80 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
