MY KID UNPLUGGED SOME OF THE WIRING HARNESS INSIDE MY EMACHINE T3624. IT IS THE THREE TWO WIRE PLUGS THAT COME FROM THE FRONT OF THE COMPUTER AND PLUG INTO THE MAIN BOARD CAN YOU HELP?
  • rbrt_crln Nov 15, 2008
    THERE ARE THREE TWO WIRE COILS. I NEED TO KNOW WHERE THEY PLUG IN TO THE MOTHERBOARD
    Genius:
  • 1,913 Answers
It is lan cable andsecond one may be phone line
Posted on Nov 15, 2008
  • kishor khatri
    kishor khatri Nov 15, 2008
    ok
    read plhs text.
    those are pwr_led , rst , hdd led, pwr led, speaker.
    check on corner of the mother bord near front side .then u see some pin connect from front end .
    check those pin u find text also on mother bord in small size.readit then match with your connector.then fix it.
    also check always on coonnector the text is to read from out side .
Power went out door locked
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Mar 30, 2014 | Whirlpool Duet WFW9750WW White Front Load...
Wire came loose from driver door harness on 2000 grand prix
My service information say's that is a dark green wire . Door side connector ????? Where is this connector located ? In the door ,A pillar . I see three different connectors that wire is hooked into. Connector at the driver door master switch ,C-355 C-301
Check it out here http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter your vehicle info. Year ,make , model an engine size. Under system click on body & accessories ,then under subsystem click on power windows. Click the search button then the second blue link.
C301 (16 cavities)
Body wiring harness to the left front door wiring harness, behind the trim at the base of the A pillar
broken inside the flex boot from body to the door ?
Nov 17, 2017 | Cars & Trucks
P1300 igniter circuit
check the wiring connections inside ignitor plugs and follow wiring harness from ignitors along the wiring harness as it sounds like ther is a break in the earth wire that feeds 1 and 4 cylinders open the insulation along from the harness where it bends to see if ther is not a bad connection where a wire from both 1 and 4 connect together in the harnes normallly within 30cm of the ignitors inside wiring harness
Jan 14, 2014 | 2001 Toyota Camry
I have a 2007 1200 nightster. When I turn the ignition to the on position, it blows the ignition fuse. I have trouble shot it over and over. Changed the battery and all the fuses. I don't know what to do...
Now, this sounds like a short in your wiring, I worked on one of these bikes that the wiring harness rubbed against the frame under the left side cover, Blows a fuse and will blow the fuse intermittently or it may not today but 2 or 3 days from now riding it will blow the fuse again, Check the wiring harness the complete bike from head to tail. Look for a real close fit at any spot over/under the frame / covers then check the Insulation for a rub that may have rubbed bare any wires. Check all this. NOW, you still need to check any fuses and or wiring rubs or breaks in the wire, even check harness plugs and the metal tabs inside the plugs for burnt or hot spots. Metal tabs in the plugs can get hot then cool off due to a short and loose a connection. Blowing fuses like this is a good sign of a short in the main wiring. ie. battery,lights and or ign. to and from the handle bars and area. Look in this area for your problem. Look around the front forks and headlight area under the frame mounts. We need to check your battery connection- Follow the main battery wire from the battery to the start relay. In with the relay should be other wires and at least one fuse. Check these connections and any wires in/out for a good tight fit in the plug. Look closely for a loose wire or loose fit in this plug. Now this relay will have another wire that goes down to the starter. Look for the next largest wire out of this plug / relay follow that wire as best you can along the harness look at any other connections / plugs from the harness, even plastic ties to the frame that may be to tight. Pull this wire tug on it yank on it. Next check your key switch any wiring here should be a plug that you can un-plug and look at the wiring there.
Feb 15, 2010 | 2007 Harley Davidson XL 883 Sportster
T1oo xtra has a sensor on pass side over fender inside by motor its unplugged, its has a yellow harness plug, what is this
Hello.
All Toyota vehicles use Yellow wiring connectors/harness plugs for the Air Bag System, and their related components.
More than likely, your front crash sensor has been somehow disconnected.
Thanks for using FIxYa today.
Jan 03, 2010 | 1995 Toyota T100 Xtracab
Unplugged power button from emachine t3624 forgot how to
If you can not see a "+" and "-" sigh on the connector as well as on the motherboard, then try it both ways. If you get it wrong the first time, it will not harm anything, just plug it in the other way if it does not work. Good luck!
Jul 19, 2009 | eMachines EL1210-11 PC Desktop
Emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
Jun 15, 2009 | E-Machines T2984 PC Desktop
Emachine T3624 has no power at all
sounds like the power supply may have gone. try replacing it. or using a old PSU lying about
Jun 09, 2009 | E-Machines eMachines Desktop PC
T3624 MB someone pulled off the 3 wire pairs to the front bezel. What's the pin out for the 2 leds & power on??
According to the internet, your computer has an Intel 845GV chipset motherboard. Intel tends to use a generic pattern for connecting the front panel connectors. A description can be found on intel's site.
If this doesn't solve your problem, comment back with the motherboard model number. Look on the board, it should be printed somewhere, and it should start with D845GV...something something...
Steven
Sep 17, 2008 | E-Machines (308714) Motherboard
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
