Question about Gigabyte GA-7N400-L Motherboard
GA-7N400-L hello. I have a GIGABYTE K7 TRITON (7N400-L) motherboard with latest bios (v. F11), and cpu: AMD SEMPRON XP 2800+ on it. doesn't work properly. The problem is that my motherboard "see" my proc, as ATHLON XP 2600+ , and I have completely no idea why... What should I do to fix this problem? p.s sorry for my english
    Sergeant:
  • 207 Answers
Bartie,
First we need to properly identify your processor. You can go to AMD's website and under their Support and downloads page download a utility that can properly Identify your CPU Through codes it can read off of your chip.
If it is an Athlon 2800 this tool will tell you so. (Then it is likely your BIOS on the Motherboard just isn't recogniing it properly)
If it is an Athlon 2600 (Which I think is the more likely one) You may have purchased your Athlon from a less than reputable dealer. Who either remarked the chip themself or purchased it from a remarker at a discounted rate.
OK so now your wondering what is "Remarking" . This is when a chip dealer aquires a large amount of lower end chips then modify it by jumping some leads on the chip making it run beyond its intended rate (A process called OVERCLOCKING) and then prints a higher end processors stamp on it allowing them to sell it at a higher cost.
I hope this helps you
Dave
Posted on Nov 15, 2008
What is the fastest cpu I can put in my GA-7IXE4? PS: I presently have an 800 MHZ cpu installed. Thank You in advance.
Anything upto an AMD K7 Sempron 3000+ and will also take upto 768 Mb of sdram memory ....cheers from Scott
Sep 05, 2011 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
Do you give me a list of gigabyte ga-81rm memory suppor ?
307_sub.jpg GA-7N400 (rev. 2.0)
  1. Supports AMD Athlon™ XP 400MHz FSB processor
  2. Supports Dual Channel DDR400 memory architecture
  3. Supports AGP 8x interface for outstanding graphics performance
  4. Integrated 6-channel AC'97 audio with S/P-DIF function
  5. Provides 6 USB 2.0 for high-speed connectivity
Oct 12, 2010 | Gigabyte GA-7N400 Pro Motherboard
I have a Gigabyte GA-7N400-L motherboard CPU problem
dit you try a bios update?Some motherboard needs a bios update for a newer cpu.
Jan 17, 2010 | Gigabyte GA-7N400-L Motherboard
Gigabyte GA-7N400 Pro fan makes tick noise after shutdown
i have a tick sound everytime my computer is on use.
Dec 26, 2008 | Gigabyte GA-7N400 Pro Motherboard
Main memory
You could do that. But I would check to see if you couldn't pick up two 1 GB RAM sticks instead. Memory has gotten cheaper & Windows XP is a memory hog that likes at least 1 GB of RAM.
Dec 20, 2008 | Gigabyte GA-7N400 Pro Motherboard
Gigabyte GA-7N400 Pro2
hi
clear your bios setup with jumper settings.
or
take your cmos cell 15 minutes then put in position.
also check smps.
power cable,power supply.
Mar 26, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
ADA3700AEP5AP 3700 Clawhammer wont boot
I believe that it should work with that chip. If you have the manual for the MoBo try resetting the cmos on the board. That should put every thing back to its defaults. It is posable that it is trying to run it at the wrong voltage.
Feb 29, 2008 | Gigabyte GA-K8VT800 Motherboard
Prossesors
It will depend on what model of gigabyte motherboard you have? Do you have the exact model number?
cpu-z or everest will tell you if ur unsure.
Jan 09, 2008 | AMD K7 , 800Mhz (amdk7800mpr24b)
Where to find manuals & Drivers
Here is the link for the drivers, bios, manuals, etc of this motherboard.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1756
Good luck
Lolita
Nov 01, 2007 | Gigabyte GA-7N400 Pro2 Motherboard
System will not boot
The CPU failure was possibly due to a Power Spike, if that was the case then the Memory or Motherboard may also be damaged,  it may be best to test the CPUs and the memory on a known working system, to see what is working & what is not
Oct 13, 2007 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-7N400-L Motherboard Logo
250 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
