Question about Dell W3000 30 in. HD-Ready LCD Television
Powers on intermently sometimes does sometimes doesn't
Dell w3000 tv has power on issues can you help
  • skittlered1 Dec 26, 2008
    I also have a green vertical line down mine left side of screen?!
  • cash71 Jan 27, 2009
    Will Not Power UP!!!
    New Friend:
  • 90 Answers
If power light indicator and no video, its the inverter/ backlight. If no power at all, its the power board.
Posted on Apr 23, 2009
Hi there, i have a Dell tv model W3000 lately the tv does not turn on at all,i know power is there but the tv does not comes on. sometimes it comes on but it does not last....if i turn the tv off it does...
This is the way all of these fail. Don't buy Dell TV's.
Try this internet posted solution.
Turn on TV with remote control, if the TV does not light-up, find the Main Power Switch. Turn the switch off, then turn it on, the TV lights-up. Probably caused by poor contacts due to age and low quality parts.
Apr 27, 2010 | Dell W3000 30 in. HD-Ready LCD Television
My dell w3000 tv wont power on
There are likely bad capacitors on the power board. You will need to replace 4 capacitors, labeled c101, c304, c305 and c404. I used 3 50v 33uf and 1 50v 47uf capacitors. The originals are 35v 33uf and 35v 47uf. Replacing these should fix most power board issues.
Dec 20, 2009 | Dell W3000 30 in. HD-Ready LCD Television
No power
I agreeing with Guru it might be the blown fuse at the power supply
the tv serviceperson has a meter to test if is the fuse
is bad.
Good Luck
dbenner
Nov 17, 2009 | Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 display issue - logic board or inverter?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 11, 2017 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000
Don't buy Dell TV's. I have been fighting this problem for years.
A royal pain. Now there is no red in the picture. All blue and beige.
My solution? New TV and ABSOLUTELY NO DELL!!!
Aug 11, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell tv w3000
Try turning the master power on and off a few times. Give it a few secs inbetween power offs and that should work. It's worked for me. Sometimes it takes longer that other times to show a picture.
Nov 28, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Power want come on tv
Yes, I believe it is a power supply issue.... Problem is, I can't locate one
Oct 28, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 30 in. HD-Ready LCD Television Logo
286 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
