Question about Apple iPhone Smartphone
Iphone wont start after software reset
Hi, my Iphone is stuck on the apple icon forever affter: settings-general-reset, i did this to correct an error with the camera, thanks.
    Problem Solver:
  • 13 Answers
Try the reboot sequence that you can initiate from the phone buttons. You can find it in the iphone support on the apple site, but I believe you push down the top right button (on/off) and hold it down while you depress and hold down the "home" button (round button-bottom front center). After, I believe< either 15 or 30 seconds it should turn off and then back-on(reboot)....then you can release the buttons.
Sam Bass
Posted on Nov 17, 2008
How to master reset my Apple Iphone A1221?
Ok, I'm using my iphone 4 running 7.1.0 as my guide on this one, so I must not be using all the correct headings, but this should be close. Go to "settings->general->reset->Erase all content and settings". That should erase all personal data, contacts, songs, photos, etc... And reset all of the settings to factory default. If you think you may want to reverse this, or if you're planning on upgrading to a newer generation of iPhone and want to transfer your data then be sure you sync your phone with iTunes before doing this. Let me know if that does not work, there is another way to do it but it will require you to update to the latests version of iOS that your device can run, which will erase your jailbreak if you've installed one (not to be confused with re-lock your phone, if you paid to get your phone factory unlocked, and that does not mean a sim interposer, your phone should remain unlocked, no matter if you update iOS).
Jun 06, 2014 | Apple iPhone 3G
Tip
My Apple Iphone wont turn on. What to do when Iphone is freezing.
Hi.
What do I do if my Iphone does not start up anymore?
Here basic troubleshooting:
1 Try turning Iphone off, then back on. Turn it off by holding down the Sleep/Wakebutton until you see the red slider on display, then slide the finger across theslider. To turn iPhone back on, hold down theSleep/Wake button until the you see Apple logo on display.
2 Try pressing and holding the Home button for about ten seconds. This will close a frozen application or a stuck process. After this restart the iPhone following thesteps on point one.
3 If the above did not work, try doing a reset. Hold down the Sleep/Wake button and the Homebutton at the same time for about 10 seconds. You may see ared "power off" slider appearing on screen, then you see the display going black. Donot release Sleep/Wake and Home buttons until you see the Apple logo appearing on display. See picture below:
4 Reset all settings: Tap Settings>General>Reset> Reset All Settings. This will reset all settings to factory default. Data and media files will not be affected.
5 If that does not fix the problem, then try deleting all content and settings.
Tap Settings>General>Reset>Erase All Contents and Settings
This will delete all media and data. All settings will also be reset to default value.
6 Try restoring iPhone using the latest version of iTunes.
Connect iPhone to the computer using the data cable. When you see the IPhone in the Source list, click on Restore in the Summary tab.
If that did not work, repeat steps from 4 to 6 once more. If Iphone is still frozen, unplug it from pc, and try restarting the Iphone. Also reinstall Itunes and connect Iphone to pc again.
Ifrepeating the steps 4 to 6 did not fix your problem , then the Iphone isfaulty. In that case take it to a local Apple repair shop, or call Apple servicephone number listed on the user guide to arrange repair.
If the Iphone is faulty, sometimes reinstalling Firmware can fix it, but that, that is a risky procedure that will invalidate your warranty and damage the IPhone beyond repair. Better calling Apple before bricking the Iphone.
For this reason I will only post links on the argument.
On firmware update see:
How To Install IPhone Firmware
IPhone Firmware Download Links
Regards.
on Mar 22, 2010 | Apple iPhone Smartphone
Tip
Apple iPhone hard reset If iPhone won?t turn on, or if the display freezes or...
If iPhone won’t turn on, or if the display freezes or doesn’t respond
•Press and hold the Home button below the screen for at least six seconds, until the application you were using quits.
•If that doesn’t work, turn iPhone off and turn it on again. Press and hold the Sleep/ Wake button on top of iPhone for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
•If that doesn’t work, reset iPhone. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
Updating and Restoring iPhone Software
You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
1.Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2.Connect iPhone to your computer.
3.In iTunes, select iPhone in the Source pane and click the Summary tab.
4.Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available.
5.Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
Resetting iPhone Settings
Reset all settings
Choose General > Reset and tap Reset All Settings.
•All your preferences and settings are reset. Information, such as your contacts and calendars, and media, such as your songs and videos, are not deleted.
Choose General > Reset and tap “Erase All Content and Settings.”
•All your information and media are deleted. You must sync iPhone with your computer to restore contacts, songs, videos, and other information and media.
Reset the keyboard dictionary
Choose General > Reset and tap Reset Keyboard Dictionary.
•You add words to the keyboard dictionary by rejecting words iPhone suggests as you type. Tap a word to reject the correction and add the word to the keyboard dictionary. Resetting the keyboard dictionary erases all words you’ve added.
Reset Network Settings
Choose General > Reset and tap Reset Network Settings.
on Mar 10, 2010 | Cell Phones
3g not working on iphone 5c, I need settings
Try to
Check for a Carrier Settings Update by Tap Settings > General > About, Check for an iOS Software Update by Tap Settings > General > Software Update, Remove the SIM Card and reinsert it ,Allow the iPhone to acquire the network again, Reset network settings: Tap Settings > General > Reset > Reset Network Settings ,Restore the iPhone as new http://support.apple.com/kb/HT1414. if still not able to solve and need some technical guidance then follow Mac Customer Service .
May 30, 2014 | Apple iPhone 3G
Face book wont down load. goes to a white screen then back to the icon
this iphone repair is rated EASY,
you are having software issue and your iphone need to be reset.
Goto settings > general >> Reset >> Reset all settings
by doing this you will not loose any data. Everything will remain same it will just fix any software issue.
tech from iphone repair mississauga
Jan 31, 2013 | Apple iPhone 3G
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Apple iPhone 3G
Only sign of apple is shown on the screen
restore your iphone using itune 8.2.then jailbreak and unlock
Jul 30, 2009 | Apple iPhone 3G
Stuck on Music and wont go to the main menu
  1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted.
  2. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears restore the iPhone software.
Jul 24, 2009 | Apple iPhone Smartphone
My iphone got a problem when i install this activeMMS then after i install it ir show to reboot it but after that its not working properly if i ON my iphone it shows only the logo of apple only that i...
Hi, it seems like the application had a bug in which has damaged your system firmware. You will have to preform a full system reset, here is how to do it.
Hope this helps
Muzzi_123
Jul 16, 2009 | Apple iPhone Smartphone
Iphone not working after update
do this for ur iphone.
plug it in the computer and turn it off (the iphone and make sure itunes is open)
now u are going to hold the top and bottom button for ten seconds then release the top button and it should go in to recovery mode the comp will recognise it and will say " an ipod/iphone has been found in recovery mode' now u need to restore it and it will be fine.
Sep 14, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
85 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
