Question about Microsoft Xbox 360 Console
Won't read disks
The thing is, it not that is says disc unplayable or whatever, it's just that when I put the game in it read it for a sec, but then just says open tray. HELP!
  • Hailey Branham
    Hailey Branham Nov 15, 2008
    I have the same problem when i put a disc in the xbox 360 is just says open tray and never reads the disc
SOURCE: laser is not reading disc says "open tray" after 2 sec. xbox 360
my xbox 360 elite has 2 red lights, which im led to believe is over heating, but it had only run for 15 seconds so cant of overheated so whats the problem? regards paul.
Posted on Jan 16, 2009
buddah300
  • 15 Answers
SOURCE: my xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Posted on Feb 26, 2009
xboxexperts
  • 19 Answers
SOURCE: i have a xbox 360 witha benq drive it won't read the games
This is a pretty common problem in the 360 and sometimes it will act a little crazy with errors like "please put into a 360 console", or it thinks games are dvds and just says "play dvd" after putting a game in. This is usually caused from the laser which is either dying out not getting enough power. You can either fix it yourself which will void the warranty, or send it in to get fixed which will cost around $100 for a new drive.
first open up the dvd drive and clean it good, including the laser. Then try the dvd drive POT Tweak
if you decide to get a new laser, then click here for instructions on how to install it properlly.
If you don't want to get a new laser or do the pot tweak, you can get a replacement drive on ebay or somewhere. It must match the key stored on the motherboard, so you would need to taked the pcb board out of the old drive and put it into the new one for the keys to match.
Posted on Mar 09, 2009
localwonder
  • 6784 Answers
SOURCE: My 360 keeps saying unreadable disk no matter what game i put in
Ok, this is optical lens assembly failure. the lens is burned out and unable to scan due to lens failure. simply replacing the dvd rom optical lens assembly will restore the reading ability of your unit.
Posted on May 27, 2009
  • 51 Answers
SOURCE: games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Posted on Jun 01, 2009
Unplayable disk
something must be wrong with the laser.
Jul 06, 2009 | Microsoft Xbox 360 Console
May 27, 2009 | Microsoft Xbox 360 Console
Unplayable disk error
You will need a laser replacement, You can get them on ebay for like $15.
If you have a hitachi drive you can try the solution here.
Dec 10, 2008 | Microsoft Xbox 360 Console
Unplayable disc
have you tried cleaning your Disc.
Jul 16, 2008 | Microsoft Xbox 360 Console
Unplayable disk
Try running a disc cleaner in your system to clean the eye. That should fix the problem.
Jun 24, 2008 | Microsoft Xbox 360 Console
"Unplayable Disc"
First of all clean the disc, use warm water and a soft rag. after cleaning the disk, very carefully take apart your XBOX and use the rag to wipe off the eye touch nothing else. Place the XBOX together the same way that you took it apart. Hope this helps!
Feb 19, 2008 | Microsoft Xbox 360 Console
Unplayable disc
Open up the console and open up the CD Drive. Clean the lens of the CD Drive with some rubbing alcohol and a q-tip. Then put the console back together.
Dec 24, 2007 | Microsoft Xbox 360 Console
Xbox 360
Sounds like you have a faulty DVD drive. If you are still in warranty Microsoft should either repair/replace the console, call them and explain the situation. Otherwise, if your warranty is out, you could replace the DVD yourself, there are many places to pick up the drives, ebay is a good place to start also xbox-scene.com would be able to help.
Please rate if at all useful, thanks!
Nov 29, 2007 | Microsoft Xbox 360 Console
360 grinding noise and unplayable disc
Crack open the DVD case and see whats going on and try fixing it yourself. OR Buy a new drive off of eBay and transfer the firmware key over from the old drive too the new one.
Sep 20, 2007 | Microsoft Xbox 360 Console
Unplayable disc
Your system is fine, the disk is a different story. By moving your Xbox 360 the drive does some funky things. The disk probably has some deep grooves around the egde. In future, dont move the 360 or backup your xbox 360 games with http://www.everything4360.com Support Rich
Aug 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
