Question about Texas Instruments TI-89 Calculator
Different answer fro my TI-89 AND MY tI-81
Hi sorry everyone, not the brightest light in the shop when putting in this sum on my ti-81 9492 x 2 pi then 1000 / ans then *360 my ti-81 gives me the answer 6.036217816 on my ti-89 i do the same sum to get 15000/(791*pi)
please could anyone help im a bit thick
many thanks john
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
In addition to k24674's explanation, you can convert from a symbolic answer to a numeric answer by pressing Diamond then Enter.
Posted on Jan 18, 2010
  • 7,993 Answers
Your TI81 can only perform numerical calculation: It always give uour numbers. The TI89, a more sophisticated calculator, can of course do numerical calculation, BUT ALSO symbolic ones. You ask it for the derivative of sin(x) and it will give you cos(x).
Anyway, if you want a decimal result for you calculation above one of the numbers must have a decimal point (instead of writing 2PI write 2.PI.
The TI 89 can do exact calculations. But if you want approximate results any number in the sequence of operations must have the mark of a decimal. Numbers without decimal marks are considered integers, Integer numbers with a decimal mark are treated as floating point numbers ( meaning decimal).
Hope it clarifies things for you.
Posted on Sep 05, 2009
Words with these letters
Pianist
Ani Spit
Ani Pits
Ani Tips
Pain Its
Pain Sit
Pain Tis
Pains Ti
Pains It
Spain Ti
Spain It
Paints I
Paint Is
Inapt Is
Saint Pi
Antis Pi
Stain Pi
Satin Pi
Anti Psi
Anti Pis
Anti Sip
Pitas In
Pita Ins
Pita Sin
An Tipis
San Tipi
A I Pints
A In Spit
A In Pits
A In Tips
A Pin Its
A Pin Sit
A Pin Tis
A Snip Ti
A Snip It
A Spin Ti
A Spin It
A Pins Ti
A Pins It
A Nips Ti
A Nips It
A Pint Is
A Ins Tip
A Ins Pit
A Sin Tip
A Sin Pit
A Nits Pi
A Snit Pi
A Tins Pi
A Nit Psi
A Nit Pis
A Nit Sip
A Tin Psi
A Tin Pis
A Tin Sip
An I Spit
An I Pits
An I Tips
An Pi Its
An Pi Sit
An Pi Tis
An Psi Ti
An Psi It
An Pis Ti
An Pis It
An Sip Ti
An Sip It
An Tip Is
An Pit Is
Nap I Its
Nap I Sit
Nap I Tis
Nap Is Ti
Nap Is It
Pan I Its
Pan I Sit
Pan I Tis
Pan Is Ti
Pan Is It
Naps I Ti
Naps I It
Span I Ti
Span I It
Snap I Ti
Snap I It
Pans I Ti
Pans I It
Pant I Is
San I Tip
San I Pit
San Pi Ti
San Pi It
Ants I Pi
Tans I Pi
Tan I Psi
Tan I Pis
Tan I Sip
Tan Pi Is
Ant I Psi
Ant I Pis
Ant I Sip
Ant Pi Is
Pa I Nits
Pa I Snit
Pa I Tins
Pa In Its
Pa In Sit
Pa In Tis
Pa Ins Ti
Pa Ins It
Pa Sin Ti
Pa Sin It
Pa Nit Is
Pa Tin Is
Spa I Nit
Spa I Tin
Spa In Ti
Spa In It
Asp I Nit
Asp I Tin
Asp In Ti
Asp In It
Sap I Nit
Sap I Tin
Sap In Ti
Sap In It
Pas I Nit
Pas I Tin
Pas In Ti
Pas In It
Past I In
Taps I In
Pats I In
Spat I In
Apt I Ins
Apt I Sin
Apt In Is
Pat I Ins
Pat I Sin
Pat In Is
Tap I Ins
Tap I Sin
Tap In Is
As I Pint
As In Tip
As In Pit
As Pin Ti
As Pin It
As Nit Pi
As Tin Pi
Sat I Pin
Sat In Pi
At I Snip
At I Spin
At I Pins
At I Nips
At In Psi
At In Pis
At In Sip
At Pin Is
At Ins Pi
At Sin Pi
Oct 19, 2016 | Miscellaneous
How do I graph an equation with TI 89?
Just open the Y= equation editor and enter your equation. Use X for T. Make sure the angle unit is in radians.
Nov 10, 2014 | Texas Instruments TI-89 Calculator
How can i see the real number pi in decimals in my ti-89?
To get a numerical value for a single result, press the diamond button then the ENTER button. To have all results come out numerically, press MODE F2, scroll down to the Exact/Approx line, right-arrow, select 3:APPROXIMATE, then press ENTER ENTER.
Dec 26, 2012 | Texas Instruments TI-89 Calculator
Making PI a variable in TI-82 Calculator
The calculator does not have a Computer Algebra System or CAS: It cannot handle non numerical quantities. Every letter symbol must have a value stored in it prior to being used. If no value is stored in a letter symbol, value 0 is assigned to it. Sorry.
As to calling Pi a variable, I would not got that far, even if the calculator would give me 2Pi.
TI calculators that have a CAS are the TI92 Plus, the Voyage 200 PLT, and the TI Nspire CAS, TI Nspire CX CAS.
Apr 14, 2012 | Texas Instruments TI-82 Calculator
TI-89 incorrect answer
You're not doing anything wrong. The TI-89 simply does not reduce odd powers in square roots. If you change the 13 to 14 you'll see a rather different result.
Apr 11, 2012 | Texas Instruments TI-89 Calculator
How do i enter this question on a ti 89? 5 sin(2 pi 2000 t +60 degrees) does anybody know i would appreciate it.
Hi ssmith63,
Put the calculator in radian angle mode. The top answer is in AUTO mode and, The bottom is in Approx mode.
I converted 60 degrees into pi/3 radian which equals 1.0472 radians. I figured 5 significant digits was good enough since, you only went 4. If you have any question just post them and, I'll respond quickly.
Jan 15, 2011 | Texas Instruments TI-89 Calculator
What does "@n4" on the Ti-89?
The "@n" followed by a number represents an arbitrary integer. For example, "@n1 pi" represents a solution at every integer multiple of pi.
May 20, 2010 | Texas Instruments TI-89 Calculator
I JUST GOT MY ti-8today and don't know how to use it
To do fractions, input like this:
(1/3)+(4/9)
Granted the answer is a decimal... But you should be able to convert that to a fraction using what you've learned in math class.
PI sign: Just press [2nd]and then[^]. And voila, instant π! Exponent:enter more complicated expressions involving exponents using parentheses and the negative sign.
For further guide read: http://www2.stetson.edu/~mhale/teach/ti83.htm and http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&appId=6124&tabId=2
Please rate this!!
Aug 16, 2009 | Texas Instruments TI-81 Calculator
Can you Factor on a TI-84? IF not, does the TI-89?
Well, to answer part of your question, yes... the TI-89 does factor like this. it is inputted like this:
factor(6*x^2+11*x+4,x)
Check the catalog in the TI-84 (which is 2nd-zero) and look under F for factor()
Jan 12, 2009 | Texas Instruments TI-89 Calculator
Different answer two different calculators ti-81 and ti89
I had the same problem when I got my first 89, even though it's really a feature and not a problem.
Press the diamond key then enter to get your answer, and it will give you the decimal answer instead of the exact answer like you have been getting. Hope this helps...
Nov 15, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
263 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
