Roland sc 500 temp to low
Won't allow me to over ride trouble code must be a sensor for temp but its 80 degrees in room, and I dont have a service manual. The users manual says to wait till ambiant temp rises and is impossible to over ride untill temp rises I need an answer how to fix, a service manual or someone around orlando to service this printer. roland has abandoned this printer
hvpatel
  • 152 Answers
SOURCE: Toshiba Dp3580 service manual
find out from http://www.eserviceinfo.com/
Posted on Feb 25, 2008
  • 95 Answers
SOURCE: Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
Posted on May 29, 2009
  • 398 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: Roland SC-545EX Service Call 0110
hahahahhahaha mayra
Posted on Jun 19, 2009
niquose
  • 198 Answers
SOURCE: Need user manual and/or service manual for Canon imageCLASS C2100
here you go...this printer model is known as cp660 on other regions (based on their Web site).
http://printer1.blogspot.com/2008/03/canon-cp660-service-manual.html
hope this helps.
Posted on Jun 24, 2009
Where is radiator fan switch on 1998 olds intrigue
You have relays for the cooling fans. Did you check applicable fuses and voltage on fuse circuits? Any applicable trouble codes?
Check the coolant temp sensor. Don't replace anything unless your testing points in that direction.
The low speed fan comes on about 223 degrees F, hi speed about 230 degrees f.
If you turn on the ac, the fan/s may run? On some makes and models, if you unplug the coolant temp sensor, the fan/s may run?
Oct 18, 2016 | Cars & Trucks
Tip
Too cool or over cool in room
Indoor sensor to sense the room temp and must cut off the compressor by working. If sensor defective, compressor will continuously running resulting to over cool in room. And also 23 C degree setting temp is best cooling for office and bed rooms. If for peculiar instrument which should be kept under low temp, can be set as mentioned temp (say 18 C or 16 C )<br />
on Jan 10, 2011 | Heating & Cooling
Check engine light flashes only til I reach 30 mph, slow while acceleration, engine temp fluctuated from normal to low on temp gauge, engine rpms seem to drop lower than normal? What is wrong here?
the lowering on the temp gauge indicates a lack of coolant around the bulb of the temp sender unit or a lack of flow around the cooling system
could be from low coolant level or blockage in the coolant system from forming ice ( 16 degrees is -8 degrees Celsius which is below freezing point of water)
I suggest that you check the antifreeze ratio in the cooling system and it should be no less than 50/50 to water
any thing less than 50 % antifreeze in the water will allow the coolant to freeze up which may be your problem
coolant condition should be checked every season as it does deteriorate over time and the % ratio will drop
topping up with normal water is another method of lowering the % point
check with a radiator shop or dealer service center to get the correct % of antifreeze for below freezing conditions and keep it at that point
Dec 20, 2015 | 1999 Toyota Camry
06 rendezvous that the digital temp display for outside temp is wrong. The display reads 32 degree and it is actually 80 degrees so the A/C does not cool vehicle down. What is the problem?
Suspect a failure in the ambient air temp sensor. Has the vehicle ever been in a frontal collision? This sensor is normally located in front of the radiator assembly bolted to the rad support. If it is reading a cold temperature, it will not allow the AC to operate
Jul 18, 2015 | Cars & Trucks
Mr.Steamer Commercial Steambath CU750A temp is to high it is out of control
There are only 3 likely causes. The first and most likely is the room sensor inside the shower. This is a resistive type sensor that communicates the temperature in the room to the controller via ohm ratings. There is an equivalent ohm rating for every degree of temperature it correlates to and that is how the temperature controller knows what temp it is in the room. Often in commercial steam rooms clients tend to spray cold water on the sensor which causes damage and alters the ohm rating to the point where the sensor is relaying incorrect room temps to the controller, causing high or low temperatures. Normally when the room is hot, it causes the alloy metal of the sensor to be hot. When cold water is sprayed on it, it immediately bring down the temp of the alloy and the thermal shock warps the metal causing the resistance values to change. Set your multi-meter to ohms and remove the sensor wires from the back of the controller. You will do your ohm reading on the sensor wires. Check the actual room temperature with a thermometer. At room temp 77 degrees you should be getting 10,000 ohms, at 100 degrees you should get 5827 ohms, and at 120 degrees you should get 3759 ohms. Note as the temp goes up the ohms go down, this should help you determine if your sensor is good. The other possibility is your steam solenoid valve is stuck in the open position. Simply check if there is voltage running to the solenoid. If there is no voltage but the room is filling with steam your solenoid is stuck open and needs to be replaced. The last is the controller, and by process of elimination if the sensor and steam solenoid are good then the controller may be the issue.
Feb 02, 2012 | Mr Steam Mr. Steam Commercial Steambath...
The digitel display show room temperature in the 70's when room is very cold, thus it does not turn on when you want it to
The temp you are looking at is a error code. 72..76 is the code for room sensor. 76..80 Room sensor shorted.
Tom
Sep 30, 2010 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Indoor unit temperature between 60F & 70F after R22 charge..
The pressure changes with temperature, it is not a true gauge to ensure a proper charge.
You should have a 15 to 20 degree temp drop across the evap coil. (return air vs supply air)
Can you verify that the compressor is running?
Not the condenser, but the compressor located inside the condenser (outdoor unit)
it really sounds like it is still undercharged.
Check the temp drop, let me know what it is.
Also tell me what the outdoor ambient temp is.
( for example.... 98 degree outdoors with 85 degree indoor temp could result in pressures something like 325 on the high side and 75 or 80 on the low side.
With the exact same unit, but 80 degree outdoor temp combined with 70 degree indoor temp, your pressures could read 215 low side and 55 low side. Not to mention that more efficient units often have higher pressures on the low side because they have more coil space and remove heat more efficiently)
Aug 21, 2009 | Sanyo Split System Air Conditioner
Colorip machines to run on Versaworks
what rip software can I use on a roland sc-500? jimrothfuss@gmail.com
Nov 16, 2008 | Office Equipment & Supplies
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
243 people viewed this question
jasbo
jasbo
