Question about Dell E176FP 17" LCD Monitor
Monitor goes blank less than a second after turning on.
I also have problems with my monitor turning itself off after a 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up? The PC boots up okay and if I swap over the cables to anoher monitor it works okay, I have also tried the monitor on another 2 PC's and it works fine on them. I have also downloaded the drivers from the Dell support website but this has not been of any help??
  • Craig Abraham Nov 27, 2006
    Why would the monitor work fine in other PCs then, if the invertor board was faulty hen surely it would always be the same no matter what PC it was connected to ???
    I flashed a torch into screen and your right the picture on the screen was visible, would you happen to know what a good price would be for replacing this as it will cost me £15 in delivery charges to send back to Dell to sort ??
    Thanks for the info mate
    Abbie
    Scholar:
  • 34 Answers
If you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new
one do go burst! you have to laugh really, what next , a new on/off
button, as you work though the whole inverter !
mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.
Posted on Feb 08, 2010
Change the LCD backlight ccfl tubes. http://www.eefl.cn http://www.cn-ovl.com http://www.slim-lightbox.com http://www.rondeflower.com OVL-Good ccfl,eefl, ccfl ring, ccfl PC kits, sound controller, Lightbox, El-panel, Backlight materials inverter supplier
Posted on Dec 09, 2006
  • 47 Answers
Hi Abbie, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 26, 2006
  • The Dude
    The Dude Nov 27, 2006
    Sorry Abbie somehow I missed that in your post.
    Strange problem. Do me a favor and try the flashlight test next time it goes out on you.
    Just shine a flashlight directly into the screen, like you're trying to look into the monitor. If you can see a picture around the flashlight it's a backlight problem for sure.
    Let me know,
    Dude
  • The Dude
    The Dude Nov 28, 2006
    See...and you thought I was nuts!!! lol You might just have a loose connection somewhere, maybe a bad solder joint or chip-creep. Might explain why it worked on two other PC's. Did you move the monitor to test on other PC's?
    I wish I could give you a concrete answer to cost. Replacing the board and or the CCFL's is simple. At worst you have to do a little bit of soldering to replace the CCFL's All you need is a screwdriver for the inverter board. Finding the right parts can be a bit of a pain tho.
    I have seen the boards go for £10 on eBay and figure £35 tops new. Monitors with cracked screens but good backlight parts start at like a Pound all day long.
    It really is an easy fix. I'd think an electronics shop might go £10-20 max for the labor. Know anybody handy with a soldering iron?
    I searched for you and came up with no leads for your parts. Not even part numbers. Call Dell they can either sell you parts or give you part numbers so you can find them.
    It's a shame, if the specs were higher on that model I might have been willing to buy the same LCD as yours, used and sold you the parts you need. I'm looking for an LCD screen for a project. I only need the screen, controller board and power sections. Hell you could have had the plastic frame and stand too as a spare if you wanted. Gonna build an LCD projector but I'm looking for a screen that can handle HDTV resolution.
    LMK what happens
V7 S20PD monitor goes blank after 1 second!
This is usually caused by one of the inverter transformers that drive the backlights, or the backlight itself. The capacitors should not be ruled out, to fix it will be expensive venture.
May 16, 2012 | V7 Computers & Internet
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Picture ok for a few minutes then go blank
it is your monitor inside problem, you need to know follow issue:
1) inverter board some where the component got less connection
like MOSFET drive or capacitor swelling need to resoldering or change.
2) the back light lamps worn that most cause this symptom, need check or adjust inverter driver to match them work well
3) DC power supply filter capacitor swelling should be this problem, check and fix it.
hope help you something do well, please feedback any question any time,
pleaae take a rating let me know how much helped you thanks!
May 27, 2009 | Dell E176FP 17" LCD Monitor
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Dell E176FP 17" LCD Monitor Logo
2,685 people viewed this question
Alun Cox
