Question about HP Ingersoll Rand Schlage Biometric Handpunch 2000 rs232-serial 512
Hand punch 3000
Calibration error
    New Friend:
Hand punch 3000 says error 64 but it replace a new lithium battery
Posted on Sep 05, 2013
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How do i calibrate the spreader
Your AccuGreen 3000 Drop Spreader was calibrated at the factory. However, a spreader's calibration may change or slip over time or during periods of heavy use.
You may check the calibration of your Scotts Accugreen 3000 by first adjusting your micrometer setting to 6. Turn the spreader over so that you are looking at the outside of the bottom of the hopper. Use your foot to hold down the trigger (if your trigger has a locking mechanism you can lock it in place prior to turning upside down). With the micrometer set at 6 and the trigger squeezed against the handle, the front edge of the projecting ridge on the shut-off bar should be aligned with the calibration line located on the 2nd or 3rd tooth from the center. Some of the older AccuGreen 3000 Drop Spreader spreader models do not have a raised ridge. On these spreaders, line the front edge of the shut off bar to the calibration line.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and raised ridge or front edge of the shut-off bar meet. If you have any difficulty checking or adjusting the calibration, contact us and we will be happy to help walk you through the adjustment.
Again, thank you for taking the time to contact us and for your interest in Scotts. Please feel free to call us at 1(800)5438873 anytime we may be of assistance.
Mar 03, 2011 | Scotts Company Scotts& Accugreeen 3000...
How do i calibrate the accu green 3000
According to Scott's:
To adjust calibration, do the following: Adjust the micrometer setting to 6. Flip spreader over. Use your foot to squeeze the trigger against the handle. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. To adust alighment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Sep 18, 2010 | Scotts Company Scotts& Accugreeen 3000...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Scotts 3000 spreader needs calibration?
I found the manual that came with the spreader.. recalibrated it and it works fine.
Apr 28, 2009 | Scotts Company Scotts& Accugreeen 3000...
Compass calibration
Hello. First day I use this device, and have found this tips for compass calibration (as I understand, compass calibration depend on satellite signals - so before compass calibration it's better to get good signals from satellites):
- keep device at horizontal plane (as from message "hold level");
- turn it slow, but not too very slow.
It's better don't turn device, but get device at hands, and turn around himself with it with constant slow speed, and keep horizontal level of device - by this way I have a more accurate calibration, than turn just in hands or on the table.
I hope this will help.
Jun 23, 2008 | Garmin GPSMAP 76Cx GPS Receiver
HP Ingersoll Rand Schlage Biometric Handpunch 2000 rs232-serial 512 Logo
733 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
