Question about Gateway Computers & Internet
In my windows media center it says no tuner available, I checked to see if it was hooked up inside and it is. This cp is only 4 mo old and worked perfect until Itook out some restore points> Is that what happened?? I tried to install a driver but said it wasnt compatible?? Any suggestions?? Thanks
    Genius:
  • 1,913 Answers
8u have tio reinstall sound driver.
Posted on Nov 15, 2008
  • kishor khatri
    kishor khatri Nov 15, 2008
    give me your computer model name or mother bord number i give u driver.
Panu poh ba isave sa m.card ku ang themes download ku poh sana reply poh sana kau agad
unang una, anong model ng cp mo? pangalawa, nokia ba toh? pag nokia yan ganito ang pag save ng themes sa memory card.
1. tanggalin mo ang memory card ng cp mo
2. kung meron kang usb card reader, ilagay mo ang memory card mo dito
3. ikabit mo sa usb port ang card reader
4. pagkatapos madetect ng pc or laptop mo ang card, buksan mo kung saan folder mo naisave yung na download mong theme sa laptop o pc mo.
5. copy and paste mo lang yun sa memory card
6. ilagay mo ulit yung memory card mo sa cp mo
7. tapos pumunta ka sa menu>tools>file manager>select mo memory card
8. makikita mo dun yung mga natransfer mong themes and pindutin mo yun
9. tapos install mo and follow mo na lang ang instruction sa cp mo
10. pagtapos mo install, delete mo na lang yung theme kasi naka install na un sa cp mo.
11. pde mo na ding di delete para back up.
Nov 04, 2010 | Cell Phones
Tip
How to Build: Antenna Tuners
Get you a metal box about 4 inches X 4 inches. Use 2 female Cb antenna inputs from old Cb radios or Radio Shack. Get a old Am radio tuner out of a AM radio(530-1700 khz.) Buy or scrap up some copper wire; big gauge I used. Wound 8-10 turns about " 1 inch round close tight wound. Solder to AM tuner- C1 it shall say on top of Am tuner. Solder Center of Am tuner to Ground(Metal box). For those who know electronics the Tuner is 0-365pf Am band 530-1700khz types. OK, back to assembly. drill a hole for the Two Female Cb Inputs on both sides of metal box. Attach copper wire inside to center taps of Inputs on both sides. Drill a hole for Am tuner and Screw on its lock nut and place a knob on it. Solder all grounds of Female Antenna inputs and Tuner Ground and all Grounds to metal box. Use a washer and Bolt to lock down Grounds to Box. This is how it operates after you use a Jumper to hook to TX of Cb radio. Antenna to other side. Its just a simple L/C network. The Tx travels through copper wire(coil) inside box and gets shunted to ground by the right level of PF Capacitance. The operator tunes it in to get a close to 1.1 to 1.5 SWR ratio. Its simple, but helps with bad Antennas.
on Apr 01, 2011 | Radio Communications
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Media Center for Window XP, TV don't work.
Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
Nov 02, 2009 | Microsoft Windows XP Home Edition
I have an HP media center pc the m370n, and i just upgraded to windows 7 ultimate. I can not get the tv tuner to work, what could be wrong? thanks. Ryan
think you'll find the drivers for the tuner are not compatible with windows 7. according to the hp website this is an xp machine. download the windows 7 compatibility checker from here to check http://www.microsoft.com/downloads/details.aspx?familyid=1B544E90-7659-4BD9-9E51-2497C146AF15&displaylang=en
Oct 14, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Windows xp mce
Do you have tv tuners installed and setup properly? Media Center 2005 is just the software, the computer needs to have hardware tuners in it and hooked up to external antenna or cable.
Feb 15, 2008 | Philips TV Tuner Video Capture PCI Card -...
Pc will not see tuner
no but that is way to low in vista need leats 2 gb ok
Feb 11, 2008 | Microsoft Windows Vista Ultimate Edition
No Green light on tuner
After trying to set up TV using Windows Media Center my tuner seemed to get configured and the light came on. It still isn't recognized by Media Center though. Dale
Feb 04, 2007 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
I am having problem with tv tuner card
i think your tv tuner is defective even if it is new, still factory defects can happen. try to install it in another computer, if you experience the same problem then it is defective. but have you checked your device status at device manager under sound, video and game controller. if you see a yellow apostrophe or a question mark it indicates that your tv tuner is havent been installed yet. try to double click the device and you'll see update driver then try to intall it by choosing automatically driver, be sure that the cd driver is inside your cd rom.
Sep 18, 2006 | Philips TV Tuner Video Capture PCI Card -...
Computers & Internet Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
