NEED ADVISE ON HOW TO RESTORE DELL 1550 INSPIRON BACK TO ORIGINAL FACTORY SETTINGS, HAVE ASKED DELL FOR HELP BUT FOUND THEM VERY UNSURPORTIVE,
In the beginning when folks purchase their computers in today's world. You have to go to their recommended download site and gather up your models recovery disc. If they provide the recovery disc for you in the box that is a serious plus. Some people just do not know how to download things off the net not know how to burn them. Companies do not wish to spend the large amounts of money it takes to provide each customer with a system restore disc these days.
Some companies still store them and other do not offering people no support at all when their computers fail. Anything computers before 2008 maybe even newer, will not have disc support let alone driver sites to go to. If you are lucky enough to have such a deal get all the goodies while you can. Companies have also set aside on your computer recovery section on your hard drive where you can recovery from there, So support is null and void really of any real change of talking to a tech guy mainly oversees, although at the time of sale sure we offer great support for your new machine. It can be frustrating to say the least been there done that one.
Now to solve that matter of restoring your computer and you are not going to like hearing this, you are going to need a factory restore disc, or you will have to follow those informative members who know if even there is a restore section on the hard drive or a method in which you can do this without a disc again often the case. If you do not have one available for your computer?
You can go back and restore from a saved image file you did or a backup in which most folks did not do in the beginning of time since they first started using their machines. "Imperative" Now you know why?
It simple really, for those of us who have done this several hundreds of times. Personally I like to get rid of all the factory junk that comes with computers these days. Most of it is junk filling up your computers, some of it is needed but really not needed with the deployment of Win 7. I always keep a copy of Windows 7 and use this disc when restoring computers. It is called and O.E.M. disc. Or you can just for you purchase a Win 7 disc. This way no junk no extra things on the hard drive that will pop up or disturb you with buy this and buy that sort of thing in your face.
You know why because Windows 7 in its update process keeps loads of driver and hardware files and software it seeks on your computer during the update and installs them for you if there is a driver that it does not pick up "Rare" it offers a solution as to where to find that driver file at. Thus support is done virtually. Unlike XP where you still have to seek out some driver files after restoring your machines in most cases. So my advice is Windows 7 if you can get a disc for yourself by all means do it. Make sure that you have the resources within your computer to do this update.
Place the system restore disc in the DVD or CD drive of your machine. Boot from that source first boot. Go to BIOS or where it set set the boot order and do this most machines are designed to boot from DVD or CD drives by default. Follow the onscreen instructions and there you have it a restored computer.
It would take me forever to seek out restore discs for every single question I answer. The main questions are, "how to restart my computer without a password" How do I restore my computer back to factory settings? If you do a little more research on your subject matter there are solutions other than just having a restore disc. However as much as I would love to be able to give everyone there complete answer and a complete solution to this issue. Many brands come into play and many different models as involved for me to find out if yours has restore capabilities located within in C:\Drive. John
SOURCE: I want to restore my DELL LAPTOP to the factory settings?
Okay, do as follows.
(a) Boot the computer. When you see a blue bar with www.dell.com on the screen, hit Ctrl + F11.
(b) On the next screen, click "Restore".
(c) Next, click "Confirm".
(d) Let the restore process run. It will probably take 10-ish minutes. Don't touch it while it's doing it's thing.
(e) When prompted, click "Finish" to reboot the computer.
(f) When prompted, click "Yes".
(g) When prompted, click "Next".
(h) After the computer restarts, click "OK".
SOURCE: restore dell inspiron b130 to factory settings
restart the laptop... as soon as you see the big blue DELL screen hold ctrl and press F11.
if done right, this should bring up the dell restore utility, just follow the prompts. takes maybe 15 minutes.
SOURCE: reset to factory settings
If the system has the original Dell image, then just after the Dell Bios splash screen should be a black screen with w blue bar at the top with www.dell.com at the top.
At that screen press CTRL + F11 to initiate the PC Restore program.
SOURCE: how do I restore factory settings on my dell
Turn
off and reboot your computer. When you see the Windows flash screen,
depress "CTRL" and "F11". Be sure to press them simultaneously and
release them simultaneously.
Select "Restore" in the "Dell PC to
restore by Symantec" window and press "Enter".
Highlight and
select "Confirm" when the message shows that you wiill lose all data if
you continue. This will begin the restore process. It usually takes
about 10 minutes or so. When it's done, you should receive a message
that states the system recovery process was successful.
Select
"Finish" to complete the process and restart your system.
Shutdown
and restart your computer. Keep pressing "F8" until you see the
"Advanced Boot Options" menu. You must depress the keys before the
Windows Logo screen appears. If you wait until after the screen appears
and then press "F8", it's too late and you'll have to reboot the system
and try again.
Navigate to the "Repair your computer" option
Select
the appropriate language and click "Next".
Sign onto the system
as an administrator. Without administrative privileges, you will be
unable to perform the system restore.
Select "Dell Factory Image
Restore" and click "Next".
Place a check in the check box next to
the text that says "Yes, reformat hard drive and restore System
Software to factory condition" and click "Next".
Click "Finish"
to complete the process. This will reboot your computer.
