Question about Stratitec 5-Port 10BaseT Ethernet Hub (68853310038)
I have a cable modem. from the cable modem I go to a 5 port hub
And two hard wired computers. I can only get the internet on one of the wired computers and not on my laptop or the other wired computer
    Problem Solver:
  • 10 Answers
That is because most cabel internet providers only gives you one public IP. Please go to a Best Buy, Office Depot, Staples, Walmart, or Targer, and ask for a LinkSys Router. The router will do NAT (Network Address Translation) that will allow more than one PC share the single public IP. This will solve your problem and will cost an estimated $30.00. The router is simple to hook up, just plug the cabel from your modem into the Internet/WAN port on the router. And the two computers into any of the other ports. Be sure to unplug both cable modem and router then plug up the cable modem first, once the ready light is on, plug up the router.
Posted on Nov 28, 2008
How can I connect two ethernet cables to this modem?
If your Internet Cable Provider allows it,you will need :
1. Crossover-wired, or "null," category 5 Ethernet cable for the cable modem to be connected.
2. 10BaseT or 100BaseT Hub or Switch.
3. Straight through, or standard, category 5 Ethernet cable (one for each computer to be connected).
Be sure to check with your Internet Provider first.
Can't connect to laptop
You need to connect a cable from your modem into an internet port on your router and than a cable from an ethernet port of a router into an ethernet port of your hub and than a cable from hub to the computer.
Modem --> Router --> Hub --> Computer
May 08, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
I cannot connext my xbox360. internet light is not on on roiuter but i have an internet connection, how do i fix
The internet light indicates that a connection is made from the Internet port on the router to a device. This device should be a DSL modem or Cable modem.
The connections you plug the wires in a twisted pair Ethernet network into come in two flavors, DTE and DCE. There are 8 wires and two are used for transmission, two for reception with 4 unused.
The physical connections are the same on either end, so this is confusing. There are two types of cables, a "straight through cable" which can be used to connect DCE to DTE (a DTE is a computer or X-Box or something that is the end of the line, while a DCE is a Commuications device, like a hub. A modem or hub or cable adapter is a DCE. You plug your computer (DTE) into a modem (DCE) with a straight through cable. To plug a hub to a hub, you need either a crossover cable or a "X" port on the hub.
While many new devices are auto-sensing, the WGR614 is not, and they caution you that you may need a crossover cable, and to check the manual for the modem or cable device.
A manual for your router can be found at but I don't know what kind of DSL modem or cable adapter or whatever you have so I can't guess further. I found the explanation for "why is my internet light off" with the suggestion that you might be plugging DCE to DCE.
If you want to make your own crossover, it is not hard if you have the clamp for the RG-58 8 position connector.
Pins 1 and 2 are TD + and minus, and 3 and 6 are RD plus and minus. For a crossover cable, you need to swap 1 with 3 and 2 with 6. See
Jan 10, 2010 | NetGear WGR614 Wireless Router
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Only one computer can acces the internet in my hub , I have a Linksys NH1005 hub , I'm using cable dsl , but only one computer can acces the internet , it does not matter wich port
If you want to use more than one computers you will need to replace that hub with router. Best is to get wireless router because in most routers you have places for wired connections and also wireless connection.
Reason why you can't use more than one computer is simple because most ISP are allowing only one computer to be connected from DSL modem.
Oct 24, 2009 | Computers & Internet
I have my internet through my cable company and i want two com hooked up but are not going to have them online at the same time so can i use the 10/100 5-port model#EZXs55w by using the line coming out of...
Hello Friend
You could definately use Network Switch-10/100 5-port model#EZXs55w to Connect to Network Router or Modem using Uplink Port at back Panel of 10/100 5-port model#EZXs55w Switch.
Simply Connect Modem cable to Uplink Port of Switch and connect computers to other 2 ports of switch. Allow computers to get Automatic ip addresses..if computers still not getting ip addresses auto--contact cable company and config your cable modem to use NAT or enable NAT--
Oct 10, 2009 | Computers & Internet
How can i connect an additional pc to my rca dcm245 cable modem? i have an ethernet hub.
Hi there.
What you have to do is plug in the Ethernet hub, run the Ethernet cable (RJ45) from the modem to the "internet in" or "internet" socket on the hub, it will the one which is separated from the others.
Then connect an ethernet cable in port 1 to your first computer and a cable from port 2 to your second computer and so on.
If you experience connection problems just pull power from the modem for 30 seconds, plug it back in wait a minute and reconnect.
If you would need further assistance please post back.
Good luck and thanks for using FixYa!!
May 25, 2009 | Thomson RCA DCM245R Modem
My two computers cannot pass through my broadband provider (through the switching hub) at the same time.
that is not possible for an single isp connection you can only connect one computer at a time and hub is basically a repeater that is it simply repeats the packets it receives from one input out the others.
May 18, 2009 | Encore ENH905-NWY (ENH905NWY)
Hard Wired Port Problem
please dont assign any manual addresses in ur computer..let it be automatic...
u said that u connected the computer to Ethernet ports in the router...
check whether the light are lit in the router corresponding to that particular port..
check the ip address to that particular computer(hard wired to the router)
ip address should be or 101 or 102..if the ip addres comes in this range means its working good...
if ther is no ip means please follow this steps...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights turn on the router and wait
till the power light is the internet Explorer it should work..
May 31, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
198 people viewed this question
Top Stratitec Computers & Internet Experts
David Payne
David Payne
Are you a Stratitec Computer and Internet Expert? Answer questions, earn points and help others
