Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Loud Noise when on
When I turn on the vacuum. It makes a loud noise and does not pick up. How do I fix this problem?
  • 833 Answers
Sounds like something is caught in the fans.  If they are found to be damaged, replace them.
Posted on Nov 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Posted on Jan 16, 2008
b0sslady2001
  • 357 Answers
SOURCE: Loud Noise
I believe you will find the answer you seek by clicking on this link.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope it helps...
Marci
Posted on Feb 06, 2008
  • 61 Answers
SOURCE: Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Posted on Apr 15, 2009
  • 75 Answers
SOURCE: My bissell momentum vacuum is making a very loud
it might be the motor or the fan is messed up.have someone or you check that out.
Posted on Jun 30, 2009
  • 3 Answers
SOURCE: i have a loud noise coming from the vacuum. also doesn't pick up
Check underneath, behind the roller where the opening to the hose is. I had the same problem that was caused by a Lego lodged in the opening and when it was removed, the vacuum worked like a charm.
Posted on Jul 25, 2009
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Loud eureka vacuum
A loud vacuum cleaner usually means you have broken the fan or impeller which causes it to be out of balance and vibrates
Sep 30, 2013 | Vacuums
He dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Jul 03, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a loud noise coming from the vacuum. also doesn't pick up
Jun 16, 2009 | Kenmore Progressive Bagless Upright with...
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Mar 02, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Loud noise
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
163 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
