Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Hp does not work when press power button
When i press the power button. The light for the power button just on and off also the same with the battery light. When it start it just on for few seconds and then off again. But nothing appears on the screen. i have to leave it there 4 the rest of the day then try it the next day it work perfectly...pls can anyone help me with this.....??????
  • Anonymous Nov 26, 2008
    Power button lights but system does not boot up. Any way to make it work. have removed battery, reset ram, plugged, unplugged adapter. Tnx
    Genius:
  • 2,120 Answers
Have you tried it without the battery installed?
Posted on Nov 15, 2008
When I plug in the charger into HP pavilion dv 2000 it charges but when I press on the power button then the power button light stays for some seconds and go off with the charging light too off.
TAKE OUT THE BATTERY!!
JACK POWER PACK IN TO THE WALL
WORK NOW
DOES BIOS SCREEN GLOW , ON DEMAND.
SEE THIS, F1, F9,F10 KEY WITH POWER
ON YES, THEN POWER IS GOOD
IF THE POWER WILL NOT WORK, WITH NEW POWER PACK, AND BATTERY OUT,
THERE ARE SHORTED PARTS INSIDE THE LT
MY GUESSING Would be silly,
Mar 01, 2017 | HP Computers & Internet
Hp probook 4510 not powering up (orange light flashes a few times when power button is pressed
Disconnect power adapter.
Remove the battery
hold down power button 10 seconds
plug in Power adapter
press Power on
Aug 08, 2016 | HP ProBook Computers & Internet
HP DeskJet 3745 Printer , My Printer Cant Turn ON , Tested PW Adapter OK , How To FIx It .....Help Me!!!
Some products require time to turn on. These products might or might not give feedback in the form of blinking light(s). Wait a minute for the power light to turn on before proceeding to the solution.If your product does not respond when you try to print, press any button on the product to wake it from power save mode. Wait for the product to initialize, and then try to print again.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button Figure 1: Press and quickly release the Power button If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution Solution two: Check the electrical connections and outlet Unplug the power cord from the electrical outlet, or the power strip or surge suppressor Carefully inspect the power cord for visible damage.If the power cord or power module shows any damage, contact HP to replace the power supply. Disconnect the power supply from the rear of the product.Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor.If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.Reconnect the power module to the product. Press and quickly release the Power button (c01602202.gif ) to turn the product on.If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn the product on.If the product turns on , the electrical outlet in the original room caused the issue.If the product still does not turn on , continue with the next solution.Solution three: Check the USB cable Disconnect the USB cable from the rear of the product.Figure 2: Disconnect the USB cable from the HP product Press the Power button (c01602202.gif ) to turn on the product.If the product turns on with the USB cable disconnected , replace the USB cable If the product still does not turn on , continue to the next solution.Solution four: Check the battery If your HP product has a battery, follow these steps:Check the battery light. If the light is red,recharge the battery.If the battery light is still red after recharge, replace the battery.Figure 3: Removing a battery (example only) 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery Instructions for recharging and replacing a battery are available on the HP Web site.Solution five: Replace the power supply If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product Solution six: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product
Oct 03, 2011 | HP DeskJet 3745 Printer
After completing a print project the power light went out and now it will not turn on. I cannot see where there might be a fuse to check. Do you have any suggestions? Thanks, Jim
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. 1) Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
2) Unplug the power cord from the electrical outlet, or the power strip or surge suppressor.
  1. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  2. Disconnect the power supply from the rear of the product.
  3. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  4. Reconnect the power module to the product.
  5. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  6. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn the product on
  7. If the product turns on , the electrical outlet in the original room caused the issue.
  • If the product still does not turn on , continue with the next solution.
3) Disconnect the USB cable from the rear of the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. If the product turns on with the USB cable disconnected , replace the USB cable
  3. If the product still does not turn on , continue to the next solution.
4) If your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery
5) If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product
6) If you have completed all the preceding steps and are still experiencing a problem, service the product
Mar 26, 2011 | HP Deskjet 460 InkJet Printer
My laptop is a hp 6365 and it was working last night but then when I got home it would not turn on. When I plug it in the blue light on the charger lights up but no other lights(The lights the show that...
1. Unplug your computer and remove the battery.
2. Press the power button several times.
3. Reattach the battery, plug in the computer, and press the power button.
4. If the problem persists, look closely at the screen. If you can make out faint, dim images, the backlighting components must be replaced or repaired. If not, it is likely another issue with the physical hardware of the machine such as the screen or the motherboard.
Mar 05, 2011 | HP Hewlett Packard Pavilion dv6365us PC...
My printer will not turn on
First, try pressing and quickly releasing the Power button to start a Power On/Off cycle. Do not hold down the button. If this resolves the problem your done; if not continue on.
Inspect the power cord for visible damage; if damaged will need to contact HP to replace.
Disconnect the power supply (power module and cord) from the power source (wall socket) and the printer.
Test the power source, wall socket with or without your power bar or surge protector in place, with a small appliance you know works to confirm you have power. You may want to test the wall socket first and then test the power bar, etc. to make sure each component is not the problem.
If the appliance works then need to investigate the power supply. If the small appliance does not work you may need to check your electrical panel for a tripped breaker and possibly consult an electrician to check your electrical wiring.
To test the power supply plug in to the working power source; if the green light on the power supply does not light up you will need to contact HP to replace the power supply.
If the green light on the power supply lights up; reconnect to the printer.
Press and quickly release the Power button to turn the printer on. if the printer does not turn on you will need to check the USB cable.
Disconnect the USB cable from the printer.
Press the Power button to turn on the printer; if the printer turns on you will need to replace the USB cable.
If printer does not turn on, check the battery if your printer has one. A red light means the battery requires recharging; if it is still red after recharging, replace the battery.
If none of these steps resolve your issue before replacing the power supply try plugging the power supply directly in to a different working wall socket with no power bar or surge suppressor.; Press the power button.
If still no power to the printer you need to replace the power supply.
I
Dec 22, 2010 | HP Photosmart 8050 InkJet Printer
Hey, my dell all in one printer 810 will not power on at all. I have measured the traffo into the printer and it reads 30vDV so it has power but will not start
Hi
Disconnect the unit completely from the AC outlet for 5 or 10 minutes, then plug it back again.It will works.
Also I suspect it may be a loose power switch, or a problem with the power supply.
If it is a USB printer that derives power through the USB cable and not from a seperate power cable, then check the USB cable. That may be the source of the problem if the cable is bad.
Try the following solutions in the order presented to resolve the issue...
Press and quickly release the Power button ( ) to start a Power On/Off cycle. Do not hold down the button .
If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button ( ) again.
NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
Disconnect the power supply from the back of the product.
Press and quickly release the Power button ( ) to turn the product on.
If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button ( ) to turn on the product.
Disconnect the USB cable from the back of the product.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01896072.gif( chek the figure)
Press the Power button ( ) to turn on the product.
If the product turns on with the USB cable disconnected , replace the USB cable.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01468528.jpg( chek the figure)
If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product.
Solution six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks for contacting fixya.com
Oct 18, 2009 | Dell 810 All-In-One InkJet Printer
Will not power on
Unplug it; pull out the battery; with the battery out of the laptop, press the power button for a few seconds; let it sit for a few minutes. Then reinstall the battery and see if it powers up. This method doesn't always work but I've seen it work on more than one occasion.
Feb 26, 2009 | HP Pavilion DV6700Z Notebook
HP doesn't do anything
do one thing
take out the AC adapter and then take out the battery, then press hold the power button for 15 seconds and then put in the battery and try to start.
Further Queries are welcome
Feb 19, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
