Question about Frigidaire Washing Machines
Frigidaire Affinity Error Code EFO - Frigidaire Washing Machines
  • Anonymous Dec 30, 2008
    Have the same problem with a machine less than 2 months old...not impressed with Fridigaire NOT providing a list of error codes in their literature...
  • dalethomas6 May 06, 2009
    I am getting an EFO error code and my machine is beeping and I don't know what the problem is. Does anyone know what the EFO error code means?
We got the same error. After searching countless forums, we found the solution! There were socks/underwear/change built up in the pump. The water was not cycling through properly. It didn't even get passed the wash cycle. Cleaned it out and everything works fine. Plus, the error code list is INSIDE the washer! Go figure.
Posted on Feb 12, 2009
  • M Brannon Sep 21, 2010
    Don't know yet if this is my problem...gotta find the pump first
  • eveilwomen
    eveilwomen Jan 05, 2012
    i have had my washer for 2 years and its been nothing but problems. to anyone searching for a new washer do not buy a Frigidaire front loader they are not worth the money and will cost u even more to maintain. i also had the efo code issue and it was due to needing to replace the pump with a cost of over 125.00 and im just going to buy a new washer.
I hoy the sale error , clanes the Pump but still not working, what el se can i do?
Posted on May 21, 2012
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
  • 11 Answers
SOURCE: Resolved QuestionShow me another » What
efo enter prblem what is the problem
Posted on Mar 07, 2010
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
I am getting a EFO then E10 error message after I start a load of clothes...which means I have to cancel the load.
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Feb 07, 2011 | Frigidaire Affinity ATF7000ES Front Load...
EFO code cameup.
Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
Jun 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Flashes efo on display halfway through cycle
May 20, 2010 | Frigidaire Affinity ATF7000E Front Load...
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
I'm getting a EFO error code but it still washes everything just fine.
Dec 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error messages
Sep 11, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I have a front loading washer and it was flashing an error code "EFO' What does that mean?
I just spoke with customer support for my Affinity. They told me it was over sudsing (sp?). from using too much soap or not using high efficiency soap. Suggested running thru a cycle without soap to clear things out.
Aug 09, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
2,692 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
