FixYa.com
Tags:
Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe problem
By Charlie - usenet poster
hello, all. I've been lurking here for a few months, and it's amazing to me how
hardcore and dedicated you guys are, very impressive.
here's my problem: a couple of months ago, I bought a Saeco Vienna de Luxe.
it's a superautomatic, and has been working flawlessly until today, when it
just stopped dispersing espresso except in tiny drops. I've cleaned the brew
group plenty, but I wonder whether I should be cleaning the grinder also. it
doesn't say anything about that in the instructions, and there doesn't seem to
be any way to remove the bean container. of course, it's Friday afternoon, so
the Whole Latte Love (where I bought it) technical people are home for the
weekend, any help would be greatly appreciated.
thanks,
Jon Abbey
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 23, 2007
FixYa! (100)
JohnnyBeans
Rank:Wiz Wiz
Rating: 83%, 63 votes
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 07, 2005
Helpful (85)
maartenw
maartenw - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Jon, have a thought on that... you didn't happen to change beans
midway, did you?  One grinder setting will not provide equal brewing
results for different roasts/beans.  I owned a Vienna from early 98 to
2001, so I'm pretty familiar with the machine.  I would recommend
setting the grind setting as coarse as possible and starting over for
a good steady stream of espresso... could be as simple as that, I
hope!
Solution #3
Helpful (85)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Will it run without beans in it? Try running it and seeing if it is
pumping water in a relatively good volume without coffee.. The
reservoir is full, and the water pickup tube (if it has one) is in the
water...?
        from Randy and Silvia and Rocky
http://www.quiknet.com/~frcn/C offee/Coffee.html
        reply to: frcn at cncnet dot com
Solution #4
Thanks for Trying (70)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
<< Will it run without beans in it? Try running it and seeing if it is
water...? >>
thanks for your answer, Randy. it's a superautomatic, so it won't pump water if
there are no beans in the machine, it looks for the beans first, and if they're
not there, the warning light comes on, and it stops until you add beans. the
reservoir is full, and there is no water pickup tube, it goes straight into the
machine.
any other suggestions? one thing I could definitely use is someone to tell me
how to take out the bean container and clean the grinder. this doesn't seem to
be anywhere in the instructions. thanks...
-jon
Solution #5
posted on Jul 13, 2008
Not Rated (0)
KaffeSumpen
Rank:Wiz Wiz
Rating: 84%, 26 votes
You gave a fixya vote for the person giving you a link to cleaning the grinder. did this actually fix the problem with brewing?
Becuse dont know how cleaning the grinder will help.
You were also given a tip about putting the grinder to more coarse, just whanted to point out that if you do this first make three cups of coffe (trie) . And after that take out the brewing unit an clean it.
Make 100% sure that the filters are clean.
Solution #6
posted on Mar 03, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
http://www.partsguru.com/SaecoViennaBlack.html
Can you Help with these Coffee and Espresso Makers problems?
repair to delonghi coffee maker...
hi i purchased a delonghi... Answer This...
kenmore coffee maker . press...
kenmore coffee maker 12 cup... Answer This...
Saeco Italia
I am having a problem with... Answer This...
Missing grounds basket lid?
I picked up this espresso maker... Answer This...
I am housesitting and can
I am housesitting and can not... Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
