Question about RCA D52W19 52" Rear Projection Television
Changed the lamp and still don't work. Used a Philips E22 120/132
Had tv less then 8 months.
  • xxwee Nov 15, 2008
    I misplaced my warranty that's why I'm trying to make the repairs. I really would like your help for I'm at the end of my rope. Please help me because all I have is a giant piece of furniture in my living room .
    Genius:
  • 2,920 Answers
It should have a 1 year warranty on it send it in for repair
Posted on Nov 15, 2008
  • Ronnie Houston Nov 15, 2008
    tell me in detail what the tv is doing
I have a mitsubishi tv model wd 60638 I changed the lamp. Tv works fine for about 20 minutes then I start to smell like something is burning then picture starts to flicker, what could could cause this
You have a bad connector in the lamp. Stop running the TV immediately and contact the company you purchased the lamp from. this is common in older DLP tvs but not in one 5 years old unless you have a lot of hours on it. the connector can crack and arc inside the plug and then melt and smell terrible. It usually very repairable if you can get a ballast for it. the plug is part of the ballast.
Aug 28, 2015 | Mitsubishi WD-60638 DLP TV
I have a Philips 50 DLP HDTV MICRO DSPL and I figured the lamp was about to go out because after you would watch tv for about an hour and a half the picture would begin to flicker so I replaced the lamp...
A couple of things to check here. When you replace a lamp some TVs require you to reset the lamp hours meter in the settings in the menu (More common in projectors). If you do not do that then it will only run so many hours before shutting off again. If it is that, you should be able to turn it off and have enough time on the screen to reset that. If that is not the case then you should look into replacing your power supply board.
Aug 23, 2014 | Televison & Video
What is causing the lamp to keep going out on an 82" 837 Mitsubishi TV?
If a OEM Mitsubishi lamp was used you likely have a problem with the Ballast that drives or powers the lamp---the two pin socket for the lamp goes directly to the Ballast.
May 30, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
My tv mitsubishi wd-60735 turns on for about 2 min. then shuts off and red lamp light turns on,,,The lamp is only 3 months old.. Do I just need to replace bulb again or is it something else???
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Jul 20, 2011 | Mitsubishi WD-60735 Projection Television
Tv turns on but will turn off almost instantly.
To be honest with you, to me it seems like it's a faulty lamp... I've had a similar problem on a TV where when the TV is cold it would turn off, but after turning it back on every 5 minutes, it would warm up and start to move again... The problem was a faulty bulb... But the owner had switched it on and off so many times back to back that the ballast had to be replaced as well!
If not, it would be a faulty ballast. Those are the only two things that could be wrong with your TV in my mind. Your cheapest and fastest diagnosis is to buy a replacement lamp... even if it isn't the problem, you will not lose because you will need a backup lamp in the life of your TV!
Make sure you buy an original philips bulb. I think www.discount-merchant.com is a great reputable source. For $129, you can't lose. I call on these guys all the time. They will ship to you the same day and you will be able to diagnose further in less than a week. If it is the problem, you can call samsung and claim your lamp under warranty and they will replace the faulty one with a new one (but it will take 8 more weeks).. The new one could be your new replacement!
I don't recommend getting an aftermarket/OSRAM/LTI lamp... You may experience the same problems.
Jun 17, 2011 | Televison & Video
I own a 50PL9126D/37 50 in DLP TV I bought used and the picture is dark so I took it apart because I was told it could be dusty or could be the lamp. After I cleaned the inside screen VERY carefully with a...
Dlp tvs have dark pictures,first thing u must be alway change the tv projection lamp.Specially,if u bought used,because u don't know how long the projection lamp been inside that tv already.After u change the projection lamp,still have problems or hear alots of clickings sound too.This problems the board call the Ballast board is it dead too.This Ballast board only job are just to ignite the tv projection lamp only.
Jun 08, 2011 | Philips 50PL9126D/37B 50" DLP TV
Sony kdf-42e2000, lost picture and the 3 red lights started blinking. I did all the troubleshooting that have worked in the past, but no luck. Any ideas???
Maybe it's time to replace the lamp, have you ever changed the lamp on the TV before? If not, I recommend you do it, because it might be the main issue. Another thing can be the inverter board but you'll never know until you put another lamp in the TV and see for how ling it works, If it lasts less than 4 months, it will definitely be that board.
Dec 06, 2009 | Sony KDF46E2000 46" Projection HDTV
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
