Question about Dishwashers
I have a Delonghi Dishwasher that has an Error 4 message.
The Dishwasher was running through its cycle and then began to beep displaying Err 4?
  • Anonymous Nov 30, 2008
    I have the same problem as Marny59, Error 4 message and beep started in cycle. How can you reset the machine?
I ran Delonghi because I was getting the error 4 and it couldnt get past that first draining hoping that they could help but they just referred me to a repair man and told me I couldn't fix it.
The repair suggested that i try checking that the outlet pipe at the S bend wasn't clogged and the I try turning it off and on. I had done that by the on/off button but it didnt change.
So then I actually turned it off at the wall left it a few minutes and then turned it back on and voila..it is back to normal. No more error 4 message and it is working now as we speak
Janne
Posted on Jun 21, 2010
    Scholar:
  • 132 Answers
HI DELONGI HAVE A MAIN SERVICE AND DISTRIBUTION CENTER AT PRESTONS NEAR LIVERPOOL IM PRETTY SURE THAT THE SERVICE DEPARTMENT ON THIS NUMBER 1800 126 659 SHOULD BE ABLE TO ANSWER YOUR QUESTION ON THIS PROBLEM BESTOFLUCK GLENN
Posted on Nov 15, 2008
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Electrolux ewf1074- cycle time flashing and beeping and not running cycle
Consult the manual first, if there is no troubleshooting , contact your dealer (thinking about the warranty term)
Dec 02, 2017 | Electrolux Washing Machines
E 01 display and beeping
Hi
Check for the following if you get "E01" error message 1. Check for the vent hose whether it is clean which is less than two feet (to outside). 2. Check for the temperature sensor probes one in back at heating element and one in front by the lint filter for the temperatur rises resistance increases on both of them and visa versa. 3. Check whether the unit has been grounded. 4. Check for the element that turns off and on during drying process. 5. When first starting and dryer is cool it will dry one load of clothes, it also seems to work for at least the first part of the cycle, until clothes began to get dry then it over heats. display shows E01 and will not run until it has set for about an hour.
Thank you!
May 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Mar 09, 2008 | Dishwashers
Error codes
Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
May 26, 2007 | EuroTech 24 in. EDW194E Built-in...
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dishwashers Logo
776 people viewed this question
Top Dishwashers Experts
