Question about Compaq Armada E500 15 in. Flat Panel LCD Monitor
Computers? Easy?? Have an armada e500. on going problem. lady brought it in to fix. had windows proffessional on it but it wouldn't boot up, kept on cycling through a bootup loop. she has no disks for it so I had to search through hp and compaq. I searched microsoft and found files for a win xp home installation using floppies. I formatted the hard drive with a long gone msdos file I had. What I have is an operating machine that nothing runs on it. the cmos battery is shot but I rigged up the 3 volts necessary for it. I can't get the cdrom to be recognized. How do I wipe out everything off the hard drive and start over. This thing is driving me nuts!
    President:
  • 2,961 Answers
If you are trying to boot with a cd then you need to have your cd rom drive as the first boot option, which is in the bios (f2 or DEL on boot up). I you have your own windows CD, then you can format the hard drive using the cd.
Posted on Nov 21, 2006
Boot usb on compaq armada E500
At boot enter Boot Menu, select USB. Or , boot to BIOS and select USB boot.
Feb 02, 2013 | Compaq Armada E500 Notebook
My armada e500 will turn on, do the little compaq sign then just stay on a blank screen and won't do anything further. HELP!!!!
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
May 13, 2010 | Compaq Armada E500 Notebook
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
Administrators password dont have
Download the Ophcrack LiveCD, burn it to a CD, boot the laptop off it and it will crack the password for you.
http://ophcrack.sourceforge.net/
Feb 08, 2009 | Compaq Armada E500 Notebook
Compaq Armada E500
your product key may be on a sticker on the bottom of your laptop.
Aug 27, 2008 | Compaq Armada E500 Notebook
Compaq armada e500 boot up
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there which will prevent the continuation of the unsuccessful boot routine. If you can reach the Safe Mode, run Restore and go back to an earlier point in time, you may have to go back several times because if you have picked up some kind of malware, it may have been backed up with everything else.  Unless it is a really smart bug, you might be able to circumvent it.
Aug 22, 2008 | Compaq Armada E500 Notebook
Please help
Based on your description, it would seem that Windows is looking for a program that is no longer there and either halts/freezes or does some other thing out of the ordinary.
Initially, suggestion/procedures are:
1. Boot in "Safe Mode", that is press F8 before Windows start to boot and arrow up to select, hit enter;
2. It may take some time but soon as Windows has booted in Safe Mode, go to "Start", click on "Run", in the next small windows, type "msconfig" less the quotes, hit enter;
3. In the msconfig window, un-check everything you feel would not be needed. They maybe updates and autochecks. Normally, what is only important is your anti-virus. Or you can try unchecking everything, restart Windows and see what programs does not run or if any glitch(es). Thereafter, you can F8 again an check to restore the missing programs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Compaq Armada E500 Notebook
Notebook won't book from CD
could you start setup from windows? if you can, do that. but the not booting from CD problem, it might just be the cd cause that's happened to me where certain cd's won't boot.
May 04, 2008 | Compaq Armada E500 Notebook
How do i unlock my compaq armada e500?
I JUST LET IT SET AND IT FINALLY SHUT DOWN ON ITS OWN AND WILL NOW POWER UP.
Mar 14, 2008 | Compaq Armada E500 Notebook
Need software
Your only hope is that you have a Windows XP pro installation disk to either repair or re install Windows, although a repair is only of use if you still have the principal windows installation. How is XP still there if the notebook has been formatted? If your recovery disk ;which I recon was on another partition on the hard drive is long gone, then the only solution is to purchase XP, although XP home is a cheaper, but just as good a version please rate this solution.
Nov 13, 2006 | Compaq Armada E500 Notebook
Compaq Armada E500 15 in. Flat Panel LCD Monitor Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
