Power switch HDD led, Speakers, Power Led connections
Hi, I have a Compaq MOBO Model 06C0h, Intel Pentium 3, Socket 370 FC-PGA. Unfortunately, by mistake I pulled out some cables that I don't know where they go: Power Led, HDD Led, Speakers, Power Switch. I already figure out the Power Switch and the HDD Led. However, I haven't been able to connect the others. Can anybody help me? This is the only pc I have and I use it daily. I am not a pc guru as you may know...but I will learn from this mistake. Xnks.
  • 2 more comments
  • harp4u Nov 15, 2008
    I don't have a manual. This MOBO is inside of another case. I have being looking all night for those names on the board. There are only numbers written on the board. I also looked @ my friend's pc and yes, names are on the board, but Compaq does not have it, at least in this MOBO.
    I'm still looking for more options, xnks.
    I don't have a manual. This MOBO is inside of another case. I have being looking all night for those names on the board. There are only numbers written on the board. I also looked @ my friend's pc and yes, names are on the board, but Compaq does not have it, at least in this MOBO. I'm still looking for help with more options, xnks.
    Compaq board seems to be different from the one shown in the picture.
    I went to the site, and followed the pics. I still can't figure out the Speakers and Power Led.
    Any other options?
  • 4,806 Answers
I have looked all over for the manual with no joy, but i did find some usefull information for you to look at, here is the web address:
http://techreport.com/discussions.x/12098
make sure you have a torch handy when you connect the plugs, another bit of advice is that if you look at the connectors, it should say the same as what is says on the motherboard or abreviated
Posted on Nov 15, 2008
    Scholar:
  • 181 Answers
Ok i will give u the manual to locate the exact jacks to insert the wires.
    President:
  • 2,712 Answers
It is impossible to say which cables go where without actually knowing what cables they are. Generally, the connectors are labelled, so you know where each cable goes. But then again, you need to know what each cable is for. By chance, should you plug in the wrong cable somewhere, you could loose your entire motherboard.
My honest advice is to take this to a professional, and get them connect it for you. Will save you a lot of heartache..
  • 4,338 Answers
Read this web site info on how to plug in the Front panel, IE : power,HDD,HDD led< Power led, reset.
http://www.extremetech.com/article2/0,2845,1149953,00.asp
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
    Genius:
  • 1,913 Answers
Ok
first check in those pin u find i n samml words.
like hdd_led,rst,pwr.
then attch youyr pin in it.
fix pin as that u seen the words in out side.
all infor mation is on circuit pin.find it. and foloow .
  • kishor khatri
    kishor khatri Nov 15, 2008
    u ser power and hdd led.
    now u have rst for reset pin set it has 2 pin.check it is may be nearly hdd led .find words there .and fix that connector as u read reset from out side .
    speaker has 3 pins.
    just folow same way.
    Genius:
  • 1,847 Answers
Need more details of the cables which are disconnected
  • Legin Varghese
    Legin Varghese Nov 15, 2008
    if you look carefully you will see that on the motherboard it is written what goes there.( like HDD LED or spk etc)
  • 13,433 Answers
All the switches and leds go into the same set of connectors, the connector places are written on the motherboard you need to look at it closely,, or then you can find them also in the user manual.
Drivers 7vba-2aa5
Hello the drivers from this site should fit your mainboard:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Please unzip the files bofore you install.
Install the 4 in 1 chipset driver first and reboot.
Install next the sound driver.
Here is also the VIA site:
http://www.via.com.tw/en/support/drivers.jsp
Here is some info:
SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
Good luck
Jan 11, 2013 | Soyo SY-7VBA133 Motherboard
Hi sir/mam, i have a gigabyte motherboard 7vm333m-rz n now i m presently in tis board AMD processor is running... can i change the processor by pentium 3 instead of AMD.
-> NO
It has a Socket 462 processor socket. (Also known as Socket A,
http://en.wikipedia.org/wiki/Socket_A )
This is strictly for AMD processors ONLY, and only for AMD processors that use this processor socket.
An Intel Pentium III processor, that is not a Slot 1 processor, uses a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
List of Intel Pentium III Microprocessors,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down also.
{ If it states Slot 1 AND Socket 370, it means there are processors Intel made, that were that model, but could have been a Slot 1 processor, or Socket 370 processor.
Using the first example;
Pentium III 500E,
http://www.cpu-world.com/CPUs/Pentium-III/index.html
The first example on top, is an Intel Slot 1 processor style.
The rest of them on down are Socket 370 processors, EXCEPT for the Pentium III Xeon. (Zee-On)
It is a Slot 1 processor.
http://en.wikipedia.org/wiki/Slot_1
Want to learn more about computer technology? Post back in a Comment, and I will give you some links.
Regards,
joecoolvette
Jul 21, 2012 | Computers & Internet
How do you know if you get fcpga or fcpga 2 on the motherboard? it is socket 370 and fc pga 2 is mentioned in the manual but other 3 mention was fc pga thanks for any help
The difference between FCPGA and FCPGA2 is the internal connections to a single pin: in FCPGA2 it allows faster (133MHz) bus speeds. Mechanically they are the same - Socket 370. Your chipset VIA Apollo Pro133A is capable of handling it so you should buy the fastest P III you can find -it will work perfectly fine. Just make sure you have the latest version of the BIOS.
Nov 21, 2009 | Computers & Internet
I HAVE A SOCKET 370 MOTHERBOARD WHAT IS THE DIFFERENCE AND THE FCPGA VS FCPGA2? AND HOW DO YOU KNOW WITCH TYPE WILL WORK ON THE MOTHERBOARD THANKS COOL KID
Intel Pentium III and Celeron CPUs less than 1001 Mhz were FC-PGA.
Intel Pentium III and Celeron CPUs more than 1200 Mhz were FC-PGA-2.
However, Intel made CPUs in the 1000 to 1200 range that were FC-PGA
*AND* Intel made CPUs in the 1000 to 1200 range that were FC-PGA2.
So, all FC-PGA CPUs will work in almost every Socket 370 motherboard,
but all FC-PGA-2 CPUs require a motherboard that supports FC-PGA-2 CPUs.
Nov 18, 2009 | Computers & Internet
How to connect power led & reset ledin mother board
firstly u find 9pin jack on motherboard its near about pci slot and their is print power switch,power led and reset switch. some wires are  comnig from your cabinet their is print po sw,reset,hdd,pwd led
Sep 19, 2009 | Advantech 700 Series Intel Pentium ...
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Jan 31, 2009 | Intel FC-PGA2 Tualatin Adapter for Socket...
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
273 people viewed this question
David Payne
David Payne
