Question about Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
I had it on delay start last night. This morning is was flashing "clean", but the dishes hadn't been washed. I can't get the light to clear off. I can "cancel" and it goes through the drain cycle, but when done after opening the door to reload, then trying to start, it does nothing.
  • jwmachetta09 Nov 18, 2008
    Absolutely worked!!!!! Thanks for the help!
Posted on Nov 22, 2008
This may help: http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Posted on Nov 15, 2008
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
Oct 11, 2016 | Kenmore Dishwashers
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Clean light keeps flashing, cant get it to reset. What can I do?
Hi, if the clean light flashes it is indicating the was no rise in water temperature during the water heating cycle. This link below will explain things that could cause it and tell you how to reset the control so you can wash for now. Let me know if you have questions.
Be sure to follow the 'key dance' just as specified'
Thanks!
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 02, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Oct 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
349 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
