Question about Indesit W 123 Front Load Washer
Washing Machine not draining
I have a Indesit WM12X washing machine, with the following issue. During the rinse cycle prior to spin the drum does not appear to drain quickly or fully and the machine will not enter the spin cycle. If you drain the drum manually then set the program to spin it carries out this function. Do I have a problem with the pump or filter / blockage. Would it also be cost effective to repair or should I just replace the machine. The machine has given me no other problems. Regards Colin
I have just fixed the same problem. At the front - bottom right is the filter - you may have to remove the kick board on your fitted kitchen to see this - put a small dish under to capture water - unscrew half a turn - drain off all the water - then fully unsrew and pull out - I had money and treads from jeans blocking the filter - clean out, replace filter and fully tighten. My machine worked after this. - Steve
Posted on Mar 10, 2007
Same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
Indesit WLA111 stuck on rinse cycle
There is a drain plug and filter under the drum. You access it from the front by taking the panel under the door off. Get ready for lots of water to come out when you take the drain plug off. Clean out the area of the filter and drain plug.
Feb 10, 2014 | Indesit WA 115 Front Load Washer
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Kenmore supercapacity 3.5 , model 417.44052400 drum does't spin during the rinse and spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Kenmore Washing Machines
Kenmore Model 22722 will not drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Indesit wm12x
look into the filter of the pomp ..clean it and restart the machine
Sep 11, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
463 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
