Question about Garden
POWER TOOLS CHAIN SAWS
THE SAW STARTS AND IDLES BUT WONT THRODLE UP WE REBULT THE CARBERATER AND STILL WONT THRODLE UP HOMELITE 420
    Top Expert:
  • Garden Master
  • 77,499 Answers
Maybe it has a bad reed valve, check it.
Posted on Nov 15, 2008
WHERE CAN I FIND A MANUAL FOR THIS CHAIN SAW MODEL UT10753
You did not say who the manufacturer is of your chain saw. Is it made by Homelite?
Go to this website: http://www.manualsonline.com/ and type in your chain saw manufacture and model
Feb 21, 2016 | Garden
What oil to gas ratio
Most newer chainsaws and small 2 stroke gas gardening tools use a 50:1 older chain saws use 40:1. If you don't know just use 40:1 your saw will only smoke a bite. Use hi test gas and good quality oil
Sep 11, 2015 | Homelite Garden
What is wrong with this pole saw attachment
dont know but why not just flip the chain
Jan 21, 2018 | Saws
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
Jul 01, 2012 | Homelite Garden
Does anyone know the carb. setting for a Homelite 45cc chainsaw. Or set up procedure??
Start 1.5 CCW from lighty seated then do as the link suggests.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Dec 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Runs well untill it gets hot. then cuts out
If it's the little xl model, it's probably the ignition coil breaking down when it gets hot and therefore it can't and won't be able to handle a load. Also, scarred pistons skirt or rings could also be some of the problem here. Make sure your mix for a Homelite saw is 40:1 not 50:1 like most saws are. Homelite seems to run better with a heavier oil mixture. Good luck.
Aug 02, 2009 | Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Homelite chainsaw 420
Check to see if the chain brake is engaged
Nov 15, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
