Question about Bose Lifestyle 28 System
No sound from my Bose Lifestyle 28 system
I recently moved and set up my Bose Lifestyle 28 system (it's a few years old now). Now I recieve no sound and the system doesn't recognize that the speakers are hooked up. Even though I've checked the connection multiple times, there's no sound. Any suggestiuons?
  • Anonymous Nov 24, 2008
    We have the similar problem. Except a twist. We never touched or moved anything. No audio from the speakers. I am not seeing any light in the woofer. Am I supposed to?
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
SOURCE: I have a Bose Lifestyle 28 and want to hook my ipod up to it.
if there is a rca input available you can go to a local electronics store such as radio shack and pick up a rca MALE to 1/8 MALE cable
Posted on Feb 03, 2009
cjackHD
  • 71 Answers
SOURCE: I just replaced the dvd in my bose lifestyle 28
Replaced the DVD? Did you replace the mechanism, or the entire media center? If you replaced the dvd mechanism, you might be out of luck getting firmware to support the rest of the hardware. If you mean that you replaced the media center, the firmware is available as part of a normal software update disc through Bose. To check sw and fw-> when the system is off, press and hold 'enter' on the media center and tap the 'store' button until you see "console sw" on the display. Same with fw.
Posted on Jun 21, 2009
rodseesqi
SOURCE: Harmony 900 to control Bose Lifestyle problem.
Press the system button on the Lifestyle remote control. Move right to see a preview of the remote control. Press the down button to move into the submenus. Go down to IR Control. Select "on" System receives IR commands from another remote that has been taught to operate this system. Press exit and take a breath and try your Harmony remote. It should work. I had the same problem and this fixed it after hours of screwing around. Good Luck
Posted on Dec 23, 2009
SOURCE: Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Posted on Apr 08, 2010
Testimonial: "Thanks for your support. Unfortunately i had to send the system to Bose for repairs. Thanks anyways. "
My Bose Lifestyle 28 III system is about 2 1/2 years old. The remote has just stopped working---nothing at all. I have tried 4 sets of new batteries and still no luck. Any suggestions besides purchasing a...
A new remote is the simplest and best bet. I know of no way to repair a remote without making it irreparable. Though you might check the infrared LED i the front. Does the light on the remote illuminate when you press a button?(assuming it has that.)
Jun 22, 2010 | Bose Lifestyle 28 System
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Jan 29, 2010 | Bose Lifestyle 28 System
Our BOSE system has been working great for years and years. We recently moved, set up the system, and now the system has been very moody reading DVDs and CDs. It will take sometimes several minutes to...
I had the same problem with a Lifestyle 35 system. Use a DVD lens-cleaning disk, followed by the latest firmware disk from Bose. This should clear up the problem.
Jan 01, 2010 | Bose Lifestyle 28 System
About an hour in a movie, my sound will stop for a second and start back up. This happens about every minute. My system is about 4 years old. Is there an update disc that I need?
Here you go:
http://owners.bose.com/
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/warranty_center/index.jsp
Oct 25, 2009 | Bose Lifestyle 28 System
(Bose lifestyle 28) DVD picture is distorted, shadowy and difficult to discern
Try the settings setup and adjust the brightness, video format, or video black level. If you're using component connections then adjust the video output. You can scroll system setup through the remote control settings button.
Nov 10, 2008 | Bose Lifestyle 28 System
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28
well s video is a good picture it is not the best and when you kink one or bend it too far they are no good i recommend using either the rgb cables or YPbPr also known as component video either of these cables will provide better image than the s video
Sep 06, 2008 | Bose Lifestyle 28 System
Lifestyle 28 System
All the manuals are available online at Bose web site
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/home_theater_system.jsp
PP
Aug 26, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28 System Logo
535 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
