Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Sharp calculator I spilled coke on my desk and it got under my calculator--now the number keys don't work...what can I do i also accidentally spilled soda on my calculator and it works, but i have to press the buttons down longer for them to work
I had the same problem happen to me. What I did was carefully take the calculator apart using a T-10 Torx screwdriver to remove the back cover. I then used a compressed air can and blew air into all the crevices and holes in the calculator. I was able to dry almost all of the soda the spilled, however some of the soda dried and turned into somewhat of a sticky mess. I was able to carefully wipe the sticky parts clean with a tissue. After doing all of that my calculator worked perfect.
Posted on Dec 01, 2008
SOURCE:
Why won't my calculator add or substract?
It looks like it may have adding machine logic.
Do this key sequence:
5 + 5+ 6-. Is the answer 4?
Each number you enter is positive or negative and it is just keeping a running total, rather than adding and subtracting numbers.
Let me know if this helps.
Good luck.
Paul
Jul 22, 2014 | Sharp EL-2630PIII Desk Calculator 12-Digit...
Sharp EL- M332 caluclator- have a 'O' along top line- can't seem to get rid of it- must have accidentally selected something. It is not showing any decimals.
Hold (C.CE) then whilst holding it press (M+) for approximately a second and it will move one place along in the three settings (F, 2 and 0) F shows full decimals, 2 shows 2 decimal places and 0 as yours is set to now round to the nearest whole number. I have just been sat at my desk trying to work this out as my calculator was too set to '0'. Took me reading the 'DEC DET' text with lines pointing at 'M+' and 'C.CE' to finally crack it!
Hope this helps.
Apr 04, 2011 | Sharp ELM332BBL Calculator
My son has spilt coke on the laptop 1 key not working O
If you spill drinks on a keyboard, something is bound to break, and apparantly only the O key did... The only way to fix it is to get a new keyboard, I'm sorry. I hope this helps, Yannick.
Jun 09, 2009 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
I spilled a coke on my desk and my key pad got wet I immediately dried it off and put it upside down,but its been a little off by inserting spaces where they don,t belong(I just read this and it,s better...
Coke is sticky when dried, if you can, disconnedt the keyboard and pull the keys off, a flat blade screwdriver should work and wipe everything down.
Or buy a new keyboard for about 10 bucks
Apr 23, 2009 | Computers & Internet
Where is shift log feature in sharp EL-531 W calculator
The [2ndF] key allows access to other functions. I do not have the calculator under my nose, but I suspect under the [2ndF][LOG] you access the 10 to the power x function [10^x] or [10 to the x].
Hope it helps.
Apr 08, 2009 | Sharp EL-531VB Calculator
Ti-84+ turns on but no key function
Hi everyone,
I just had the same problem with my calculator. Only the On button worked, but nothing else. So I plugged in my calculator to my computer and I reinstalled the latest OS (2.43 I think). That didn't do anything, so I reinstalled OS version 2.22, a very old one. That made my calculator work! I think there is a problem with the 2.43 OS. I haven't tried upgrading my calculator any higher than 2.22. I'm sure 2.30 could work. Good luck. If anyone needs help in installing a new OS, I can help you.
-Eugene C.
Jan 02, 2009 | Texas Instruments TI-84 Plus Calculator
Sharp calculator
Don't know what model of Sharp you have but most sharps you can take keyboard apart and clean the rubber keypad magnets and the mylar circuit with warm water. let dry and reinstall. Check to see if Coke did not get in other parts. Do not use anything strong such as thinner. Rubbing alschol is good because it evaporates. Good luck
Jan 11, 2008 | Office Equipment & Supplies
FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Dec 06, 2007 | Sharp EL-531VB Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
407 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
