Question about Bunn BT10B Coffee Maker
Blows breaker Blows gfi breaker blows regular breaker
  • Haroldpaul Feb 02, 2009
    I have a Bunn coffee maker that's been in the closet for a year or two. It worked great and then one day it blew a breaker. Plugged it in everywhere and it kept doing it. Plugged other appliances in and the Bunn was the only thing it happened with. So I bought a new coffee pot and tucked this one away. But I miss my Bunn! I figure it must be in the cord. Any ideas out there?
  • 32 Answers
If you have a multimeter you can set it to ohms and see what value you get between the prongs on the plug. it shouldn't be 0 ohms. there should be some resistance. if you have it off--there should be no resistance (OL). and if you have it in the on position you should have some resistance. It's a fairly simple device when you take it apart. I bet that if you open it up you'll be able to see the problem.
Posted on Jun 15, 2009
    Problem Solver:
  • 11 Answers
I have never seen the inside of a coffee maker but you are describing a short condition. A conductor wire is in contact with a grounded wire. Unplug the coffee maker and disassemble. If the short is in the wiring, it will be readily identifiable either by melted (scortched look) insulation or a wire that is loose and touching a ground wire. Consider the cause of the short. If it looks like a heating component caused the short, then reconnecting or retaping the wires should solve the problem.
Posted on Apr 07, 2009
I have a GE freezer, model number FUF20DPARWH that blows a ground fault circuit breaker when it goes into the defrost cycle. The case is not "hot" when this occurs and it is plugged into a circuit th
Ralph, the only way to be sure of what is going on is to check the amp draw of the freezer when it is in defrost. If the amp draw is in range ( listed on model/serial tag ) you may have a GFI that is weak.. if unit does not defrost there will be an ice buildup on the lower half of the back wall... But with unit tripping GFI it probably is defrosting............ Ken Hawk
Jan 28, 2015 | GE Refrigerators
Pressure washer
Your fuse or breaker is either too low in amperage for the machine or if using a GFI breaker ti is probably in nrrd of rpalcement. If thr fuse is on the machine the you may be using an extension cord that is too light.
Jun 03, 2014 | Clarke Power Products AC2002A 2 Hp Air...
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
How to replace a Bryant GFCB120 Circuit Breaker
If you have a Bryant load center, you can use other breakers in it, including the Eaton GFCB120 GFI since several companies unified their design. The GFI (ground fault interrupter) or GFCI (ground fault circuit interrupter), same thing, may be required for a device you are installing, such as bathroom, kitchen or outdoor fixtures.
The Eaton series includes very clear installation instructions, but if your problem is that they are missing, then all you do is install the breaker in a open slot in the breaker panel, but you have to attach the neutral [white] wire differently. On regular breakers, the neutral goes right to the ground lug in the panel. With a GFI breaker, it goes through the breaker, and then is connected to the ground lug.
Mar 09, 2012 | Eaton Corporation GFCB120 GFI Circuit...
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
i would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Aug 24, 2010 | Kenmore Washing Machines
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Apr 23, 2009 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Most likely you have a bad or weak circuit breaker. Consult an electrician for breaker change out. Make sure that it isn't hooked up with a GFI plug. They will not work on a GFI.
Apr 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Kitchen GFI breaker goes off when machine is plugged in - off or on
Oct 30, 2008 | Saeco Magic Comfort Plus Espresso Machine
Bunn BT10B Coffee Maker Logo
164 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
