Question about Starbucks Barista Burr Grinder
Was great for several years, but no longer grinds well
Are replacement burrs available?
  • 944 Answers
The best news is that the model is still on sale. http://www.starbucks.com nothing online about new burrs specifically but i am sure they will supply If you require a machine part, operational assistance or maintenance hints, please contact Warranty Services at 1-800-334-5553. Hope this helps :)
Posted on Mar 17, 2007
SOURCE:
The bean container/hopper on my Capresso 560.01 Infinity Burr Grinder is stuck and can no longer be rotated in either direction or removed from the body. Can anyone help me unseat it?
Grinders that are used daily, especially those in coffee shops will eventually wear out. The fine settings for espresso (or even finer for Turkish grind) will wear out the plates even faster. I've seen burrs needing replacement in 3-6 months for coffee shops. Burrs set on this fine position that do not grind or stop usually means a worn burr or gummed up plate. (especially with oily beans). Either problem requires the removal of the burr set and complete disassembly of the grinder. It sounds like your '1st' problem was corrected by permanently 'affixing' the burrs to a set position and now not able to remove them without causing more damage. I did the same to an old grinder I got from the swap meet. But alas, the plastic collar cracked completely and can't be repaired. well got 1 year's worth of use and it was cheap.
** Suggest checking with your vendor or MFR for service and/or replacement.
Aloha, ukeboy57
Dec 08, 2017 | Coffee Makers & Espresso Machines
My gaggia titanium dumps the brewed coffee into the dregdrawer, how do I fix that?
Water collection in dump box can be due to any of the following reasons:
1- The Plastic screw that fastens the upper filter screen in the brew group is not holding the 9 bar extraction pressure. The O-ring seal on the screw may have hardened. Replace the plastic screw. There are two different screws. Older Pre 2004 models have a screw with flexible locking pins. Here is the link to order:
http://www.shop.partsguru.com/701R05150-Saeco-Pre-2004-long-Plastic-screw-30-Gm-Lube-701R05150.htm
The screw in newer models is shorter with a flat locking end. Here is the link:
http://www.shop.partsguru.com/Saeco-short-Thumb-Screw-with-O-ring-30-Gm-lube-0018755.htm.
2- The second reason can be less coffee which is not enough for good compacting. This leaves room for some coffee that did not squeeze out and drops in the dump box with watery used coffee puck.
3- The Conical burrs may not have been replace for several years. The steel conical burrs have a life of 2500 grinds. This machine may still have burrs that have done over 5000 grinds.
Blunted burrs need to be replaced. You can order the burrs and instructions for cleaning the grinder and replacing the burrs. Here is the link:
http://www.shop.partsguru.com/226473500-Saeco-and-Gaggia-Conical-Grinder-Burrs-Set-0018819.htm?categoryId=-1
Please check the above and fix the cause.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Mar 03, 2015 | Gaggia Titanium Espresso Machine
Where can I get a thermal fuse harness for a Krups mk7000
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Aug 18, 2014 | Krups KM7000 10 cup Grind and Brew coffee...
My Solis Maestro takes a long time to grind and no longer grinds for espresso. How do you remove the burrs to clean them? Should they be replaces?
HI
Yes the burrs will wear out. They can be replaced. To remove the outer burr. Twist the bean hopper counterclockwise until it stops. Lift the bean hopper out. There is a cream colored ring with 2 tabs that will lift out holding the outer burr. To get the inner cone burr out is a little more difficult. We use a vice grip and grab the burr, and lock the pliers to it. Then with a quick movement clockwise on the pliers, you loosen it. Then clockwise unscrew the burr. When you install the new burr, it truns on counter clockwise until it stops. Insert the new outer burr. Push down so the tabs will lock in. Install the bean hopper into the correct slots ( 1 large tab and 1 small tab). Twist clockwise to turn on and test. Remember it must be grinding to turn to a finer grind but can be turned to a coarser grind any time.
Jan 24, 2011 | Solis Maestro Electric Burr Grinder
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
Not fine enough grind
This model grinder won't do espresso. There is a DIY mod available online that involves disassembling the machine, and recalibrating the burrs to produce a finer grind. I did it on mine, it was definitely better, but it's not going to get you to the coveted 30 second pull for your espresso. Search on Starbucks Barista Grinder Mod. It is a great grinder otherwise, very reliable.
Jan 09, 2010 | Solis Maestro Electric Burr Grinder
I need a replacement bottom burr for the cuisinart dbm-8. the bottom burr broke. all i need is a new one. can't find a place to buy it. hoping for a lead.
Give Cuisinart Customer Service a call at 1-800-726-0190. Or you can contact them via the web at www.cuisinart.com/support/us.html
They can get you the parts you need.
Hope you found this helpful. Best regards!
Jul 07, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
MDF very coarse grind
Several possibilities loom:
1. Same burrs for 25 years? don't be cheap replace them!
2. Dirt in the threads of the burr carrier, or the threads that recieve it?
Let us know what works
Dec 18, 2007 | Gaggia MDF Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
535 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Pierre Laplante
Info2011
Level 1 Expert
Steve Allison
Steve Allison
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
