Pop3 server does not respond in 60 seconds
Cannot receive email in outlook.yesterday i could not send email it said server did not recognise sender.I use virgin broadband
  • 1 more comment
  • emmalauren Nov 15, 2008
    thanks yes still ntl but configured correctly
  • Anonymous Nov 27, 2008
    it says POP3 serverdoes not respomd in 60 seconds. How do I fix this problem?
  • arvinpilar Mar 04, 2009
    i cannt connect to pop3sever,log onto incoming server mail server pop3 outlook could not connect to the incoming pop3 bec yor mailbox on the server was in use,
  • 4,806 Answers
If the server is still NTL try to manualy reconfigure the settings, here are the settings you need: Protocol = POP3
Incoming Mail Server = pop.ntlworld.com
Outgoing Mail Server = smtp.ntlworld.com
hope this resolves the problem
Posted on Nov 15, 2008
  • Lee Hodgson
    Lee Hodgson Nov 15, 2008
    sounds like the software is corrupt so a re-install of office would be the only way to go from here, back up your emails and contacts before you re-install because you will loose them if you don't
I can send emails but can't receive any
Do you use any 3rd party software to check your email (like Outlook)?
If so, you should probably check your email account settings, specifically the POP3 and SMTP server settings. The POP3 server is for incoming email and SMTP is for outgoing emails. So in your case you will have to double check your POP3 server settings.
Hope this helps you!
Feb 27, 2015 | Microsoft Windows Live Mail
I can't send my emails,because the message says the server rejected the sender's email address of henrysichan@sbcglobal.net. This is not my email address. My address is scajaeger12@sbcglobal.net. Can...
If you are using outlook, go to Tools > Account Settings > under your email address, highlight it and click Change. Then change your email address to scajaeger12@sbcglobal.net and make sure the POP3 & SMTP settings are correct. Click More Settings, then click Outgoing Server. Then check the box that says My Outgoing Server Requires Authentication. Then click Use the same settings as the incoming mail server. Click Apply & Ok. Close & reopen Outlook then check if it is Ok.
Sep 29, 2010 | Dell Inspiron 1000 Notebook
This message pops up when I try to receive email on microsoft outlook. Task 'pop3.telkomsa.net - Sending and Receiving' reported error (0x80042108) : 'Outlook is unable to connect to your incoming...
Probably your settings or configurations for Outlook is not properly set.
Refer to these sites for conguration settings using M/S outlook.
1. Configure outlook anywhere(MS Office 2010) @ http://technet.microsoft.com/en-us/library/cc179036.aspx
2. Configure outlook anywhere(MS Office 2007) pdf @ http://occs.odu.edu/projects/exchange/outlook_anywhere.pdf
Hope it helps.
Aug 23, 2010 | Microsoft Computers & Internet
I am using outlook express as to retrieve myemail from comcast. When I open it it shows connecting and then freezes up and finally not responding. I am not able to open any operations in express.
Before you can use it you have to setup the email account. In that you have to provide the port numbers of incoming and outgoing servers (ie, pop3 and smtp). It can not access all types of emails. if your email server is compatible then only would it retrieve and send emails. So, please check the type of email server you have. If it is not pop3 then OE may not connect to the mail server.
Nov 17, 2009 | Microsoft Outlook Express
Outlook not receiving mail or sending
You need to know the POP3 (Incoming mail) & SMTP(outgoing mail) server names.Your service provider can tell you these.
When you are in Outlook
From the menu- go to
Tools
Email Accounts
Email
Add a new Mail account
Server Type POP3 Type in the server name
Server Type SMTP Type in the server name
Your Name, Email Address given by your service provider
Log In User Name and Password
Save all these info. Close and restart the Outlook.
If this helped you, please give a rating.
luciana44
Oct 02, 2009 | Microsoft Outlook Express
The issue is: Unable to Send/Receive emails from winThe host 'POP3' could not be found. Please verify that you have entered the server name correctly. Account: 'POP3', Server: 'POP3', Protocol: POP3, Port:...
You are receiving this error because of one of two reasons:
1) Your email account is not set up properly. Click on Microsoft Outlook, click on Tools, then Accounts. You will see a window with columns stating Account-Type-Connection. If an account is set up then click on it then click on Properties. Click server tab and you will see the SMTP server block and the POP3 server block. Both of these fields will read as follows: pop.XXXXX.net and smtp.XXXXX.net. Your Internet Service Providers name will be in the XXXX. If these are not set up properly then you cannot connect to send email. If they are filled out correctly then you need to call your Internet Service Provider and inform them of your situation. Their server is not working properly.
Don't forget to 4 star this solution.
Jan 15, 2009 | Computers & Internet
POP3 CAN'T SEND USING THIS ??
hi...unless you've configured your email client (outlook, outlook express, etc)to use pop3 and smtp you wont be able to use this method for sending mails.....
aol acounts need to be configured for pop3 and smtp as do hotmail and gmail...each service has unique server names and there are pro's and cons to setting it up....your service provider will have the details of pop and smtp servers....a way round this would be to open your email and create new message and copy/paste the details you need into the new mail
Jan 07, 2009 | Dell Inspiron 1501 Notebook
Outlook express
hi,
go to accounts properties and in the properties page you can see the tab named servers, under server tab you hav to uncheck the box which says logon using secure password authentication.
if this doesnt help plz let me know..
thnk u
Jun 11, 2008 | Avanquest System Suite 8: Windows
Outlook Express - email
ur pop3 server may be nmma.sancharnet.in at port 110
ur smtp server may be nmra.sancharnet.in at port 25
try these...
Jan 23, 2008 | Computers & Internet
Mail server setup issue
Create the New Account(User), and Configure all the new settings.
Dec 27, 2007 | Microsoft Windows Server Standard 2003 for...
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Since those early days of laptop production, Acer has grown to offer devices in every category. From netbooks to high-powered gaming units, there is likely to be a laptop computer made by Acer to fit the needs of just about any consumer. The handy features along with the cool looks make Acer the world leader among the uprising brands also making them the worthy competitors of a large number of brands. Along with the cool style statement suitable for different age groups of customers, Acer products are available at affordable prices, support acer. Amazing features with attractive looks and affordable price range makes Acer brand one of the best choices for laptop users. Even though Acer has created a successful name in the market due to its high efficiency products, acer computer support might come with its share of difficulties which might be faced after a period of time, becoming a source of a lot of trouble for its users. If you are also facing any kind of issue with Acer laptops then, there is no need to worry because we have a team of skilled professionals who will resolve all your issues perfectly without consuming much of your precious time and they can be contact acer support. Issues faced by Acer customers: • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues • Windows 10 upgrade problems • Computer Tune up issues • BIOS update Our services for Acer users: Our world class services can be guaranteed to customers once they call on our acer customer service number for assistance regarding Acer products. All your query or issue related to Acer laptops that you want to get resolved in the most efficient way possible will be get dealt by some of the greatest minds in this job with highest levels of experience. Contact our acer technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our Acer customer support number. Get all your trouble sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 21, 2018 | Acer Computers & Internet
Computers & Internet Logo
781 people viewed this question
David Payne
David Payne
