Question about Brother MFC 420CN All-In-One InkJet Printer
How to clean printer head for brother mfc j265w
    New Friend:
Hi .. i have a similar problem ... i juste replaced the Black cartridge ... and when i run a "test print" or an 'alignment print" ... the whole black ink block doesn't appear at all .. only the Magenta, CYan & Yellow are ok. HELP ! ;)
Posted on Feb 03, 2014
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-5540cn Print Head replacement
Its quite siple to do if you are able to use a srewdriver... 1#: Go get a 2.hand dcp 110c or 115c at eBay with a good printhead (and a broken scanner glass???). It should print without probs! opening mfc 5440 is nearly the same as a mfc 215c, since all brother printers are of the same built :) follow pictures here http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c For your mfc you have to unfasten some more screws which can be seen very well. After that you can take up the cover. Now you should realize that it looks the same inside as on photos given in the link. Read the rest of "how to change the printhead" here: http://www.fixya.com/support/t209702-get_color_print_black_works_fine there is just one more difference to your mfc! You have to take out the sensor in the ink cart assy of your mfc 5440cn which is clipped at the side and reinsert it into the cart assy of the "new" one! This sensor is placed at the BK cart and signals the mfc that there is a HBK cart. Thats it. This job could be done for a novice within less than an hour. If there are questions afterwards or during surgery post it here!
Posted on Oct 05, 2007
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
cene765
  • 787 Answers
SOURCE: I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 02, 2009
  • 270 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
pineworks
  • 4345 Answers
SOURCE: how do you clean printer heads of Brother mfc
Hi There
This is worth a go.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
How to get printer to grab paper?
Your printer has a mechanical problem. and you should take it yo repair. Probably som internal part has broken and should be replaced.
Normally this kind of faults can't be repaired by user because the so called "reparation kit" is only available for authorized repair shops.
Jun 23, 2015 | Brother MFC-J265W Multifunction Printer...
Brothe mfc-j430w ink absorber full
Have a look at this link below. Try the purge count reset first and if that works have a look at cleaning out the waste chamber inside the machine. You must remove the casing and waste bottle, clean and refit the pads, and re-assemble the machine. It is a slow and messy procedure. It may be simpler and cheaper to just replace the machine.
http://resetmenow.blogspot.co.nz/2013/09/printer-reset-brother-mfc-j265w-and-mfc.html
Dec 12, 2014 | Brother MFC 420CN All-In-One InkJet...
I need information why MFC J265W wont print or copy.
During a print head cleaning, the printer moves ink through the print heads. This ink has to go someplace, and that's to the "ink absorber". Now, this absorber is full and needs to be replaced or the printer could overflow onto your table and make a mess.
The part may be user-replacable, or require a service visit, I don't know.
Sep 03, 2014 | Brother MFC Office Equipment & Supplies
Unable to initialize 4f "brother MFC-J265W"
Sorry I have tried your suggestion and it still give the same error. By the way the count of the clean was bellow 6000 and I reseted any way.... :( Still looking for a solution. Thx.
Nov 16, 2012 | Brother MFCJ265W AllInOne Inkjet Printer
Brother printer (model MFC-J265W) not printing black - how do I fix?
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 14, 2012 | Brother MFC-290C Multifunction Color...
My cd wont install can you help to install my brother printer MFC-J265w
Hey there. You can download the drivers for the specified printer by clicking this link.
I hope I was able to help.
Jul 27, 2011 | Brother Office Equipment & Supplies
Connecting my Brother All in One MFC-J265W, "Line"
just make it manual ansering from menu of printer
Dec 07, 2010 | Brother Office Equipment & Supplies
Brother MFC 420CN All-In-One InkJet Printer Logo
2,562 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
