Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
My saniflo toilet wont flush
I have a Saniplus toilet. About a week ago I used the toilt and it wouldn't flush. The motor runs weakly but the toilet doesn't flush. How can it be fixed? Whe I flushed the water spilled out of the tank ,that is on the floor.
  • Anonymous Mar 30, 2014
    The toilet flushes well but there is no sound from the pump when shower is working and shower water is not being sucked away
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
    Scholar:
  • Saniflo Expert
  • 115 Answers
Most likely is a blockage in the blade or impeller. Or the check valve in the discharge elbow might have been installed backwards and does not open up properly to allow the waste to pump out.
Posted on Mar 21, 2013
You need a new capacator. The motor is trying to run but does not have enough electricty to get the motor up to full speed.
Posted on Apr 26, 2009
  • 145 Answers
IT MAY BE BLOCKED UP
Posted on Dec 12, 2008
Saniplus pump sounds like a jackhammer
I'm glad you asked today, and not 3 months ago!
We also have this model, and ours is hooked to a septic tank, and with a whole lot of trouble, I believe we have your answer.
It is: Toilet paper.
You can pull up the Sani-flush people on line, and they will help you disassemble your unit and clean it. You should find it bound up with a big wad of toilet paper. The newer toilet papers, particularly the softer/gentler/stronger ones, are more glue than paper, and will clog up everything. After our latest go-around a few months ago, we had to go to some stores and buy an assortment of toilet papers, and put samples in glass jars with water, and shake them, to see which would disintegrate, and which stayed together. Because of this, sounds like you will find this the problem. Best not push the motor, or it may burn up, and be quite expensive to fix.
Be blessed,
Dec 24, 2013 | Saniflo & Saniplus& Macerator Pump
Non return valve saniplus toilet
The valve could be defective or could have become clogged.
Dec 06, 2013 | Saniflo & Saniplus& Macerator Pump
Sanislim keeps on running
does anybody know where you can purchase spares for the sanislim just im looking for a replacement motor?
Feb 26, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniplus toilet when toilet is flush the masorator tank leaks around the lid, nnot nice seeing \yuck streaks run down
Is not recommended to use 90 degree elbows in the discharge pipe. Is recommended to use 45 degree elbows back to back with a small piece in between or long sweeping elbows. Using hard 90 degree elbows creates resistance in the discharge pipe and does not allow the unit to pump out the waste as efficiently as it should.
Oct 26, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
After I flush the toilet, the motor continues to run and not stop. The only way to stop the motor is to kill the power to the unit. Please advise. Thanks
The float or float switch is sticking. You will need to get into the pump and clean the area.
"It's a dirty job, but someone has to do it"
Good luck
Feb 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
The SaniPlus toilet was just installed in my basement about a month ago. The water and waste will not go down. The motor continually runs, but the water level does not go down. Could it be blocked or is...
There could be a blockage somewhere in the drain pipe or inside the pump casing not allowing the waste to be pumped out. Refer to the installation manual/technical data manual and take a look at the schematic diagram for the Saniplus, It will show every component inside the pump casing, the short discharge pipe (# 7c) and long elbow (# 8) may be split open or not attached properly and waste water is just cycling inside the pump casing and not pumping out.
Dec 30, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
NOISY SANIFLO
Always an issue, guessing it is on a tiled floor? or up against a tiled wall?
I put some thin foam / Bubble wrap underneath and behind mine to dampen the vibrations. It also helps if you box the unit in and use foam to quieten the noise (on top and around the unit). Depending upon how long you have had it, it may also need a clean out or possibly even the motor bearings are getting a bit worn, creating some noise with the excess movement.
Good Luck
Jan 07, 2010 | Saniflo SaniPlus-Elongated SaniPlus...
I fitted a saniflo plus about 3 months ago engineer been out 5 times even changed unit last engineer said it was toilet paper stuck in tiny hole at bottom of motor he said it was due to not flushing...
This could be a problem with the capacitor which drives the blade and impeller. If it goes bad it will pump water only but when solids are flushed, it will jam the blade and cause it not to spin. You may have to replace the capacitor/condenser.
Nov 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
1,925 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
