Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Homelite chainsaw 420
The saw starts and idles but wont throdle up caberater has been rebult still wont throdle up
  • Anonymous Dec 01, 2008
    The saw is around 15 years old would it have a chain break ?
  • Junejor Dec 10, 2008
    I have the same problem with my ut-10829 16" homelite chain saw. Not sure what fuel line hose go the the fitting on the ZEMA carb? Carb has 2 fitting, one larger then the other.
Check to see if the chain brake is engaged
Posted on Nov 26, 2008
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Chainsaw wont run idle
Hi, adjust the idle screw inwards, regards Phil.
Jun 26, 2012 | Homelite ZR10926 16" Chain Saw
Does anyone know the carb. setting for a Homelite 45cc chainsaw. Or set up procedure??
Start 1.5 CCW from lighty seated then do as the link suggests.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Dec 28, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Saw will start will chock out, when chock is
Your symptoms indicate a lean condition. Check to be sure the muffler and/or spark arrestor are open and unobstructed. If all the parts are installed properly and your mixture screws are between 1.5 and 2 complete turns OUT, the saw may possibly have leaking crankshaft seals. The saw would need a pressure/vaccuum test at a repair shop to verify this.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
How do I adjust carb on homelite b3850d chainsaw?
Should b 2 screws on side of carb. One is low speed adj and one is high speed adjust. Turn screws all the way in until they bottom, not too tight--turn them out 1 1/2 turns. Start saw and adjust the idle screw by turning in until it starts to sputter and turn out until is idles smooth same for hight speed only adjust at high speed
Aug 07, 2009 | Homelite Garden
Runs but wont idle / Homelite330
Try adjusting the idle. The will be a couple adjustment screws, there will be an (H) and (L) you will need to turn the (L) First tighten the sdcrew completely then turn it 1-1/4 turns. This will be a good to start. Then just turn it small amounts until you get it to idle. Also there should be an idle adjustment you can adjust.
Jun 06, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
My homelite wont idle
When you pull the trigger on your saw lhile looking near the carb you will see the throttle plate moving back and forth as you pull it. The end of it usually rests against a screw with a spring. Screw the screw in some so the throttle doesn't come back so far.
Mar 01, 2009 | Garden
POWER TOOLS CHAIN SAWS
Maybe it has a bad reed valve, check it.
Nov 15, 2008 | Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
360 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
