Question about Car Audio & Video
Will not eject cd from head unit
When I went to change cd's today in my cars head unit after ejecting one cd and switching to another the cd did not seem to grab and go in the player so I pushed it in. It shows "no disc" and will not play. Did I possibly put the disc in upside down by mistake? What would cause this & how do I get the cd back out????
Thank You for any possible help.
Josh B.
  • tfboarder1 Feb 24, 2009
    I have a cd in the head unit and i press the eject button and it says it is ejecting but cd does not come out. any solutions?
    Ryan
3 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: EJECT? LOAD? Device will not eject the disc .READ. >>HELP<<
Hold ATT, SEL and EJECT.
Posted on Jun 16, 2007
  • 55 Answers
SOURCE: JVC head unit problem
Do you have a "RESET" button on your stereo? Check your owner's manual to find it. I have a JVC unit in my car and the reset button is a small hole behind the detachable face. Take the end of a pencil or a pen and insert it in the tiny hole and hold for a few seconds. This should reset the stereo so you can get the CD out. Hope this helps...
Posted on Aug 30, 2008
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
My cds won't play and they will not eject. I have an in-trunk cd changer.
If your radio works and you press mode .Does head unit recognize cd,s
It should display no cd,s cd error etc
The reason i ask this is to confirm that connection is ok to stacker
To eject PRESS AND HOLD eject button,insert credit card under cartridge,push fully in and move left/right untill eject
This will locate micro switch,so you can check discs
Jan 25, 2010 | 2004 Mitsubishi Endeavor
CD will not eject from unit.Word'IN' keeps
you can try either pushing the reset switch (which will be a small indentation either on the face or the subpanel behind the face) or disconnect power to the radio for a few seconds.
Nov 30, 2009 | Car Audio & Video
CD ROM has disk but this will not eject - there is no little pin hole on the vostro 1710 anywhere, nor does hitting eject from the Bios screen work....
Cd-rom will need to be extracted from unit the pinhole is lickly on the back of the unit most are. good luck please do leave postive feedback ether way for your free answer today.
Nov 17, 2009 | Dell Vostro 1710 Laptop
Cd player in ford expedition quit showing CD
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Nov 14, 2009 | 2003 Ford Expedition
Trouble ejecting a CD
It's not a fuse because the unit is working.
Try switching and ejecting all cd's. Don't keep trying for more than 2-3 minutes at a time or you could ruin the eject mechanism. Every time a CD comes out, grab it and try to empty the unit. Then look for issues within th eCD's that are causing it not to eject.
Jan 28, 2009 | 2004 GMC Yukon
JVC Car Stereo
The head unit should have two separate +12V connections: One that goes to a switched 12V power that is switched on/off via the ignition and one that is always energized at +12V. If the head unit's switched +12V lead is not connected, the unit will not turn on (except for when +12V is first applied to the "always on" lead, in which case it will immediately eject the CD). Please respond if this is not the issue. Hope this helps!
Mar 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Car Audio & Video Logo
246 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
