Question about HP Office Equipment & Supplies
After putting a new black and white ink cartridge into the printer, it keeps printing the alighnment sheet everytime I turn the printer on. Ugh! What a waste of ink.
    Scholar:
  • 181 Answers
Actually it is given in that allign page printout that how to stop this.
but listen the procedure.
after the allignment page is printed just place that allignment page in the scanner .the readable side of the page on the glass.then press OK/ENTER what button present in your printer.
the allignment will start.the printer will read the page.and allignment will get completed.then after u ON the printer it will not give you such problem till u replace the cartridges.
Posted on Nov 15, 2008
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Can't get printer to print in black
unfortunately some printers will not allow such and needs to have all the cartridges working for it to print. this is regardless if the black is still okay. i suggest to go to your nearest store and purchase one.
Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Hp2210 all in one. i put a new ink carthridge in. it keeps telling to alighn carthridges. i press enter & the printer alighns the carthridge # prints the report. the printer keeps telling me to alighn...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
It uses far too much ink when not printing. Let
Your story is common and the best reason to trash this printer and put it down to one of lifes bad experiences.
Cheers
DeJudge
Aug 08, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Installed new ink cartridge and it won't work
HI
did you check if the printer printed a cartridge alignment sheet.
you can try power flee initially
take out the cartridge
unplug the power cord
press the power button for 30 seconds
and then replug the cable
when it asks for putting the cartridge
put the cartrige in its respective slot
also make sure that you keep t least one paper on the tray so thst the printer prints an alignment sheet
,it shjould work fine
Hope this helps
Take Care
Jun 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Lexmark X125 not printing at all.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark X125 All-In-One InkJet Printer
Have an eson stylus cx9400F
Every time you do a nozzle clean routine in an inkjet printer, like the Epson CX9400Fax, ink is wasted. When it is $20.00 for a quarter ounce, that is wasteful to your wallet too. The nozzle head cleaning routine flushes your ink from the cartridge through a tube to the nozzle, where it mostens the nearly microscopic holes and flushes hardened ink residue away.
The wasted ink from machines often goes through a rubber gasket or wiper, and into a large, thick felt pad, maybe an inch thick, hidden deep inside, near the bottom of the printer, where it eventually soaks in and dries. In some machines, this happens every time you start the printer, so it makes sense to keep it plugged in. Each cartridge uses some ink, even if you only use it for black and white, so you pay a lot for something you don't even use.
Unfortunately, HP and Epson abuse the trust that users put in them. Word is that HP makes more money on cartridges than it does in printers and plotters. This leads to poor printer design that makes it impossible to refill cartridges, get 3rd party cartridges, or use a printer for black and white and not waste color ink.
May 19, 2008 | Epson Stylus CX9400 Photo Printer
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
Alighning test
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Mar 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
142 people viewed this question
Ben Johnson
