Question about Uniden Cordless Phone
Uniden cordless phone. No dial tone.
I cannot get a dial tone. The number shows up, the word talk shows. Can't answer or make a call.
  • 12 Answers
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Posted on Nov 15, 2008
How to get a dial tone on your uniden 6.0 cordless phone
If you have a phone line that is active, lift the handset from the cradle, enter the number and press TALK. Or just press TALK if you want to verify that you have a tone signal.
Aug 27, 2011 | Uniden DECT 6.0 Cordless Telephone...
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
Phone and answering machine are connected properly
I am still in need of a solution. It is not a 2 phone (cordless) it is 1 and know I have not solved the problem, I was hoping you would be able to help. I am not interested in purchasing anything other than what I already have.
Please help me resolve my problem, it doesn't sound like anyone has looked at or reviewed it. Thank you
Jan 07, 2009 | Uniden DXAI5588-2 Cordless Phone
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
No dial tone when the talk button is pushed
the circut inside is acting up and will need repair, this can happen whenthe batterys are low in the phones and the base does not detect them , also the detect circut coud be bad , and or the automatic pick up circut for the answering machine
Oct 15, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
"Unavailable"
you put it on the handset with the answering machine for a few seconds and that is how you register it.
Jun 27, 2008 | Uniden Cordless Phone
Speed dial instructions
make sure phone is off not in talk mode- then press the memory buton-press desired number 1-9-press memory button again,the display shows enter name -press memory button to save the name.then the display shows enter number-enter the number then press memory again and you will hear a tone that confirms
Oct 05, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
1,063 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
