2008 Ford F-350 Logo
Posted on Nov 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove mirror glass 2008 ford f350
How do I remove the cracked exterior mirror, passenger side.Thanks
  • Anonymous Apr 08, 2009
    HOW DO YOU REMOVE THE SIDE MIRROR GLASS ON A F-350 2008 W/TELESCOPIC MIRRORS ALL POWER
gerry bissi
Level 3:
  • Ford Master 4,390 Answers
  • Posted on Mar 06, 2009
gerry bissi
Ford Master
Level 3:
Answers
4390
Questions
Helped
3060722
Points
11499
Here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
How to remove mirror glass 2008 ford f350 - 429f568.gifuploads/images/429f568.gif" alt="429f568.gif" class="h_mi" />
Installation
  1. Remove the sealing boots How to remove mirror glass 2008 ford f350 - a8bd649.gifterior mirror motor.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn eachHow to remove mirror glass 2008 ford f350 - 95e6577.gifntil the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
How to remove mirror glass 2008 ford f350 - 52fef14.gif class="h_mi">Align the friction pins vertically to the exterior mirror glaHow to remove mirror glass 2008 ford f350 - s3o~us~en~file=ani_caut.gif~gen~ref.gifo snap the pivot ball into the socket. 52fef14.gif
  1. s3o~us~en~file=ani_caut.giHow to remove mirror glass 2008 ford f350 - ed69017.gifif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand,How to remove mirror glass 2008 ford f350 - a10e39d.gifhe center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
MFDS JF
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2015
MFDS JF
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
5054
Points
Where can I find the ford jack pin mirror
5 Related Answers
Anonymous
  • Posted on Jan 08, 2009
SOURCE: passenger side mirror
If you need to replace the entire mirror - it's a little involved. First you need to take the upper extension panel off from behind the mirror (black triangle) - just pull it of starting at the top. It will snap back on later. Next - remove the different screws holding the door panel in place (not the ones behind the mirror yet!) One is under the handle (pull it out and pull out the filler panel - small plastic thing that has a hole to pry it out). Then take off the rear red light - also pops off - and remove that screw. Finally - pick up the rubber filler where your fingers pull the door shut and remove these torx bolts.
Now is the tricky part. Snapp off the entire interior panel. It will pop off - but very difficult. It will sound like it is breaking! Start at the outer bottom corner - and use a door panel remover tool - check Amazon or E-bay - to keep from breaking things. Pull it out from all around the bottom and sides and then lift it up over the door lock. It good to have a friend help here. The panel will still be held on by a cable - that is your door release - leave it alone and let the panel hang by it (or better, put a box under it to rest on).
Now...remove the three bolts holding the mirror on - have a friend help hold the mirror while you do this or it will scratch your new car! Since the inner panel is off - you can also disonnect the mirror plus and remove it. It sounds silly - but the only reason to remove the door panel is to unplug it!
Get you new mirror and reverse the steps.
If you are just replacing the glass (non-heated) - get a replacement from the dealer. Adjust the mirror all the way to the inside and reach behind and pop it off. CAREFUL - put tape over the entire glass as it will likely break even more! Remove your connectors if heated - and replace (and reconnect) with your new glass. It just pops back on!
Replacing glass is easy - just be careful of cheap imitations on e-abay). And never use cheap flat glass on the passenger side! The DOT has special requirements for mirror glass - buy it from gmpartsdirect.com or your local dealer.
kb
Anonymous
  • Posted on Oct 27, 2008
SOURCE: Replace passenger side power mirror clearance lamp (bulb only).
If you are facing the passenger side mirror adjust the top (large) mirror so that it is turning in towards the truck as far as it will go. Then look behind the mirror in the bottom righthand corner (outside bottom corner) and you will see a silver metal clip. Take a straight head screw driver and push on that clip and the lens will pop out. Then you simply unscrew the bulb holder from the lens and replace your bulb. Good luck!
Anonymous
  • 1214 Answers
  • Posted on Jan 29, 2009
SOURCE: need to replace passenger side view mirror 200 GMC Jimmy Diamond
On my '97, there was a triangular shaped piece of plastic on the inside trim that had to be removed. I think all three mounting screws were under that. It's been a few years, but I think that was how it was done.
I remember it was pretty easy though.
Anonymous
  • Posted on May 22, 2009
SOURCE: 2008 Ford Fusion Wing Mirror Replacement
I checked Ford Focus mirror replacement and it seems to be the same. This is for the manual, unheated mirror.
Remove the mirror cover inside the door - slide a screwdriver behind the cover and pry loose carefully.
Remove the single 10mm bolt and the mirror comes free.
NB. Do not drop the bolt into the door.
Anonymous
  • 60 Answers
  • Posted on Jun 21, 2009
SOURCE: Passenger side mirror replacement procedures
If its a power mirror there is more thing you will have to remove to get to the wires but if not there is a screw on the corner piece on the inside of the door. just pull the screw out and the bolts (3) that hold the mirror on are behind it. If it power then you will have to remove the door panel to access the wiring to disconnect it
1helpful
Craked right side mirror
the glass is serviceable. Please rate, thanks
Removal
  1. Position the exterior mirror glass in the full DOWN position.
  1. Using a suitable tool, release the locking tabs from the exterior mirror motor and remove the exterior mirror glass.
    • If equipped with heated mirrors, disconnect the electrical connectors from the exterior mirror glass.
7helpful
On my 2008 ford F350 the driver side mirror marker lights are not working. I need to know how to repair them. Thanks
If it's just that the bulbs that have burnt out you'll need to position the exterior mirror glass inward toward the vehicle.(Note: Use caution to not trap the side lamp assembly wiring during installation, or damage to the wiring may occur.) Using a flat blade screwdriver or something similar, push the mirror side lamp assembly forward while releasing the retaining clip. Separate the bulb holders from the mirror side lamp assembly and remove the side lamp. Replace the bulbs and reassemble. I hope this helps you out.
2helpful
2002 Mountaineer. How do you change the light bulb at the bottom of the driver side rear view mirror. Dan
SECTION 501-09: Rear View Mirrors 2002 Explorer/Mountaineer Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Glass Removal
NOTE: Exterior mirror glass is serviceable only on vehicles built after July of 2001.
NOTE: Passenger side exterior mirror shown, driver side exterior mirror similar.
All mirrors
  1. Position the glass in the full up position.
  1. Locate the notch at the bottom of the exterior mirror glass.
  1. Release the exterior mirror glass.
    1. Insert a long flat-bladed screwdriver in the notch.
    1. Push the screwdriver into the notch until the glass is released.
Heated mirrors
  1. Position aside the exterior mirror glass.
  1. Disconnect the electrical connectors.
All mirrors
  1. Remove the exterior mirror glass (17K707) passenger side or (17T675) driver side.
Installation
Heated mirrors
  1. Connect the electrical connectors.
All mirrors
  1. Position the exterior mirror glass on the exterior mirror motor.
  1. Place a hand against the back of the exterior mirror housing and a hand flat against the exterior mirror glass. Press the glass in place until fully seated.
Passenger side mirroe is broken from the neck...
is it just the glass that broke?
  1. Position the inner edge or the exterior rear view mirror glass to its maximum travel.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Place a shop towel between the exterior rear view mirror glass and the hand to avoid personal injury in the instance of glass breakage.
    Grasp the outboard edge of the exterior rear view mirror glass and pull outward.
  1. Remove the exterior rear view mirror glass.
    • If equipped, disconnect the heated rear view mirror glass electrical connectors.
Installation
  1. If equipped, connect the heated rear view mirror glass electrical connectors.
  1. NOTE: An audible click will be heard during installation.
    Press firmly in the center of the exterior rear view mirror glass until it snaps onto the exterior rear view mirror motor.
Mirror glass replacement on drivers side
i don't have aviator. here's explorer, should be the same.
You will see a small rectangle where the screwdriver goes in. You are pryingtowards glass. The retention is about a 3 inch rectangle that has a lip around it that snaps onto a rectangle on the mirror body.
All mirrors
    1. Push the screwdriver into the notch until the glass is released. (and pull screwdriver towards glass)
Heated mirrors
All mirrors
Installation
Heated mirrors
All mirrors
99 explorer drivers side mirror vibrates
are you trting to tighten the mirror glass or the mirror where it attaches to the body? I don't think glass is removable in 99. Only can try to press on glass to seat if unseated. not too hard.
  1. Remove the front door trim panel; refer to Section 501-05 .
  2. go to car-part.com for a used mirror. Page with * is cheapest seller.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
SECTION 501-09: Rear View Mirrors 2001 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass, 2001 model Removal
All mirrors
Heated mirrors
All mirrors
Installation
Heated mirrors
All mirrors
1helpful
Replacing burned out turn signal bulb in passenger side mirror.
I'm pretty sure the light is part of the glass. The mirror glass is available seperately. Check Ebay or tascafordparts.com for a discounted part. Or, car-part.com for used one. Page with * is lowest price.
here is 2003 Nav. I don't have 2004. May be similar. please give good rating if this help. Good luck
Removal and Installation
  1. Position the mirror glass to obtain a gap at the top edge of the mirror and carefully pull the top edge of the glass away from the mirror housing.
  1. Disconnect the heated mirror electrical connectors.
  1. Remove the exterior mirror motor screws and exterior mirror motor.
    • Disconnect the electrical connectors.
  1. To install, reverse the removal procedure.
How do I install a new F-350 passenger side (only) glass mirror
Since it was just the glass that was broken, I had to remove the extra parts that came with the new mirror I purchased from Ford service department. Once I made the change it all made sense!
57helpful
The glass of my 2008 Suzuki Forenza passenger (exterior) sideview mirror is cracked....
I suggest you get one of those manuals people get nowadays to
do it yourself.. My nephew use it to repair my car and it's totally repaired now. Here's the website he got it from. www.reliable-store.com
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
