Question about HP Computers & Internet
My disc drive will not load cds. This is a new computer
  • HP Master
  • 4,806 Answers
Need more information please
Posted on Nov 14, 2008
How do i wipe al the files out of my computer had a virus and cant use my wireless either could u help me please
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.After the system recovery application has loaded,follow the prompts to reinstall the Operating System
Sep 24, 2011 | Computers & Internet
How do I download or get gateways 500 gr recovery disc ? I need everything reistalled
To start the systemrecovery:
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 22, 2011 | Gateway 500GR PC Desktop
Wish to set factory defaults
Sep 20, 2011 | Acer Aspire 5610-4648 Notebook
Am in process tranferring vinyl to cd using sony compact disc recorder and not computer,ran out of audio discs last week purchased some verbatim discs high speed rw but will not work on my machine can you...
Hi raymackie265
You are right , don't use cds for computer ( cdroms ) but well audio cds . Pay attention to this point when purchasing new stuff . Regarding the issue with cd-Rw , it's a compatibility issue with your Sony device and you need to check if the recorder will accept CD-RWs . If yes ( and it should be yes ) , try to find lower speed discs but you need to find audio cds . I ' m using a Pioneer recorder and it works fine with any kind of audio cds , not with cdroms .
Best regards ,
fanaudi .
Aug 30, 2011 | Verbatim 10PK CDRW 80 MIN 700MB 4X12X...
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
XPS One will not read CDs or play DVDs
1.use original disc, bcz some brand drives not supported all the discs available in the market.
2.cheak with other disc,if any disc cant read ,then
* Open Your CPU system cabinet,then cheak the data cable and power cable of the Dvd/Cd Drive.(You may change the other power card in your system already had)
* change the data cable
3.if u still have the problem,then finaly replace the new drive.LG Dvd Drive is beswt one.because it can read all discs.
Mar 09, 2010 | Dell XPS One All-in-One TV Desktop with...
When i insert disc into d drive it asks please insert disc into drive d
The reason may be due to:
1. Empty Disc (check with some other computer)
2. Disc may not be inreadable format ( check with other computer)
3. If this happens only in your computer, then try with some other CDs. If problem with all the cds used in your laptop, then check your cd drive for any defects.
I hope this is helpful to you
Thanks
Mar 07, 2010 | MSI Wind U100-280US Netbook
DVD drive wont run DVds or CDs
I have a dell desktop computer Dimension 9150.
My DVD drive is not working. I can run DVds.
Can you help?
Apr 02, 2009 | Dell DVD-rom DVD Drive
My cd is well ....i have no idea
Sounds like a tough problem to have because half of the CD drive is working fine (the reading part) but half isn't (the writing/burning part).
Here are a few suggestions:
1) try a different CD writing program, if the Wizard says the CD-Rs are full, try a version of Nero or a freeware burning program.
2) if, when you load the blank CD, Windows says that it's unable to burn it, it might not be a CD that your burner can recognize. If you are using different or new CDs, try another one or borrow someone else's blank CD. I've had it happen where a set of CDs that I bought were bad and couldn't be used. Also, some cheap CDs don't work on some CD burners.
3) It might be a bad CD drive. If it's an older computer, you might have to get a new CD drive. Before doing this, I'd try reinstalling the software and drivers for your CD burner and try both the suggestions from above. Good luck
Sep 09, 2008 | Compaq Computers & Internet
Won't load music CDs
Reference page 56 in your manual. This is because the system doesnt know or have info (these must be new CD's). Just add in the info and you'll eb set! thanks!
Oct 07, 2006 | Bose 3 2 1 GSX System
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
